Author Topic: TT or XT500 triple clamps.  (Read 3867 times)
« on: November 09, 2008, 12:01:19 am »
$20 + postage?
Will hit ebay within the week if no interest here.
Nathan. 04000 23847
Re: TT or XT500 triple clamps.
« Reply #1 on: November 09, 2008, 12:14:06 am »
what model yr are they off?
« Reply #2 on: November 09, 2008, 12:39:19 am »
Buggered if I know.
What's the difference?
« Reply #3 on: November 09, 2008, 12:47:32 am »
one has more/less offset depending on forks (leading axle/non leading axle)
« Reply #4 on: November 09, 2008, 12:50:47 am »
These came with a set of non-leading axle forks, so I assume they're from the same bike.
Can measure off-set if needed, but they look like non-leader triples.
« Reply #5 on: November 09, 2008, 12:54:39 am »
ok thats all i need to know. im looking for a set of Pro Fabs/White brothers and needed to get an idea of what the 2 types looked like in flesh
« Last Edit: November 09, 2008, 01:04:05 am by LWC3077 »
« Reply #6 on: November 09, 2008, 01:16:24 am »
The TT i do know had leading axle  the early xt didnt, Brent from darwin perhaps would know when a change occured and how to id that head set
« Reply #7 on: November 09, 2008, 01:20:40 am »
yeah i know 76-78 TT was non leading axle and 79 onwards TT was leading axle
76-79 XT was was no leading axle
80 onwards XT was leading axle. i think i got that right
« Reply #8 on: November 09, 2008, 02:00:17 am »
theyd be TT500c-e 76-78 tripple trees had straight forks/solid handle bar mounts TT500f gh had leading axle /solid handle bar mounts same as yz125/it175def,
XT 500c-f had straight forks/rubber mounted handle bar clamps and hole/slot in steering stem for steering lock and XT500gh had l/axle forks and rubber mount bars.
tanks and frame tank mounts are different between the straight and leading axle forks also
TT5Matt
« Reply #9 on: November 11, 2008, 09:18:25 am »
Thanks for the info guys.
Scrap metal run is rapidly approaching... Alloy is still 60c/kg, so it looks like they're worth more as scrap than parts.
« Reply #10 on: November 19, 2008, 05:00:50 pm »
Now on Ebay, 'cause I forgot to take 'em to the scrapper.... :-[
Item number: 320319190053
