Author Topic: TM125 Spark Plug  (Read 7661 times)
Loydee
TM125 Spark Plug
« on: September 08, 2007, 07:09:29 am »
Hi there preparing to race debut me TM125 on Sunday.Still on some ancient plug which fouls/oils up if in wrong gear or stall. I bought a B8HS as I read was correct one gets to practise field and it's much shorter... ??? Can anyone tell me what is the right one for a TM 125 (1974 model). Thanks in advance and good to see site back again.
Doc
Re: TM125 Spark Plug
« Reply #1 on: September 08, 2007, 07:49:55 am »
Loydee the correct plug for the TM125 is an B9EV (platinum tip racing plug) or simply run a B8ES. The 'HS' series of plugs are all short reach and not applicable for the TM.  ;)
« Reply #2 on: September 08, 2007, 08:30:30 am »
Take a 9,9.5 and a 10 EGV with you.Then you can tune your engine to the track.Short squirts a 9 long, fast & flat out a 10.
« Reply #3 on: September 08, 2007, 08:44:21 am »
can you get 9.5 plugs ?
« Reply #4 on: September 08, 2007, 08:51:51 am »
yes he runs duck tape around the isulators :O)
« Reply #5 on: September 08, 2007, 11:55:06 am »
Also 10.5 ,11 and an 11.5.
Then when you finally wade out of the kiddie pool you realise there are 'wonder plugs" ;)
TM BILL
« Reply #6 on: September 08, 2007, 06:12:52 pm »
Champion N3 always works for me  :) remember you cant ride it like a big bike you gotta keep it reving .
« Reply #7 on: September 10, 2007, 07:47:11 am »
Yeah Bill "just because you have a head like a spark plug that don't make you a Champion" I'll give you that one to add to your collection Bill,I'd imagine you'll find a time to use it. ;D
Try a DENSO IW-29 the Champion's went out with flares and Kingswoods.I get them from Toyota dealers better than NGK egv's.
