Author Topic: montesa va 125 cappra  (Read 12680 times)
Re: montesa va 125 cappra
« Reply #15 on: December 24, 2008, 10:52:47 am »
 I've got an original set of VA 125 Telesco shocks that I'll swap for a sixpack of James Squire Golden Ale only to a VA 125 owner. I think I've got a Motoplat ignition for one as well that'll cost a bottle of Jamaican rum, once again, only to VA125 owner or restorer. I don't want these parts to go to one of you parts junky hoarders. (like me)  ;D
Offline holeshot buddy
  • sunshine coast qld
« Reply #16 on: December 24, 2008, 01:13:58 pm »
its using montesa rod with different bearing caged
will keep that in mind firko
thanks rusty ;D ;D
follow me to first turn
090
« Reply #17 on: December 24, 2008, 08:08:40 pm »
Im up for a run at stanmore. Give me a heads up and i will be there. I will bring one of my shitters!
« Reply #18 on: December 24, 2008, 10:44:38 pm »
het brad i will ring next time we go down ;D
you got lots of shitters ;D ;)
« Reply #19 on: December 26, 2008, 08:47:09 pm »
me again update
bike together ready to start on weekend i hope
still has wrong shocks
and missing front brake cable and air filter element
still stuff to do but looking good
fuk this thing is light
the whole bike weighs about as much as one
of my 500cc engines :o 8)
« Reply #20 on: December 26, 2008, 08:56:08 pm »
heres another shot ;D ;D
« Reply #21 on: January 01, 2009, 09:07:15 pm »
started her up today and rode her around 8)
new engine so just rode for 5 min
everything seems ok running a 34mm bing
have put in 155 main 50 pilot
run in on that then see what happens
feels light its like riding a pushbike
after getting of my 500s ;D
« Reply #22 on: January 02, 2009, 09:10:43 pm »
forgot to say i ran it for only 5 minutes
cause its fuggin loud as
jeez its got a crackle to it
keep you posted ;D ;D ;D
« Reply #23 on: January 19, 2009, 11:04:14 pm »
bike wouldnt run under 1000rpm
and didnt seem to have a lot of compression
strange cause all new (maybe i am used to 500s) ::)
changed squish fron 1.6mm to 1.0mm
still the same  doh >:(
wont kick start roll starts straight away
got timing specs of jared 2.0 mm btdc 8)
was out reset much better nearly idles
then i felt something on my leg :o
head leaking they have a metal to metal seal
originally it had a thin copper ring on it
which looked dodgy so i took it out doh :'(
so head off again to fix tomorrow
must be a uneven surface on head
keep you posted  ;D ;D ;) ;)
squirtmoto
« Reply #24 on: January 19, 2009, 11:11:50 pm »
Hey Russ,
There's a Kwaka 500 aircooled engine for sale on evilbay under KTM
just scroll down to a KTM 200 for sale and the dude has it in his other items for sale
it's only up to $30 :o
http://cgi.ebay.com.au/KAWASAKI-KX500-A1-MOTOR_W0QQitemZ170294343331QQihZ007QQcategoryZ35231QQcmdZViewItem
« Last Edit: January 19, 2009, 11:17:36 pm by squirtmoto »
Offline JC
« Reply #25 on: January 20, 2009, 09:20:09 am »
Holeshot,
I had trouble w the heads on my VB125 too. One of my heads was cracked thro the combustion chamber from where someone had overtightened it down, probably in an effort to seal it better. VB comp ratio was something like 15:1, so I cut a copper gasket from .7mm sheet (as I recall) & never had any probs w sealing again.
I believe the VA came std w'out a copper head gasket, so my guess is that the previous owner made one to try & seal it.
« Reply #26 on: January 20, 2009, 08:05:59 pm »
put the copper gasket back in
all fixed runs great idles and seems to have
a lot of bottom end
feels really good and responsive
have to take her to a track and test properly
finally :o
shit i am getting quick at taking off head ;D ;D
could be a good thing ;D
« Reply #27 on: April 03, 2009, 07:25:33 pm »
all finished done forks
respoked front wheel
new front brake cable
straightened rear shock :o
was racing this weekend but called of due to rain :'(
cant wait now
eventually will need new shocks and  rear tyre ;D
here are some final pictures ;)
« Reply #28 on: April 03, 2009, 07:27:50 pm »
and another ;D
« Reply #29 on: April 03, 2009, 07:33:23 pm »
more ;D
will be racing her at the nationals ;D
