Author Topic: any Yamaha TY riders out there?  (Read 25838 times)
Offline David Lahey
Re: any Yamaha TY riders out there?
« Reply #30 on: November 22, 2008, 10:11:02 pm »
Oldbiker, they feel great for balance just a bit lower than standard and I don't feel cramped up in turns and the front is light enough already so haven't wanted to move them backwards. Since I did that mod in the photos on the TY250B it has probably done 10 trials and don't remember any issues with the footpegs hitting anything, so for me they are probably still high enough. I've found that main problem with ground clearance on the TY250 is under the motor as it is among the lowest of the twinshocks.
JC, I made the triangular 5mm steel plates. The U shaped brackets welded to them are from a Sammy Miller Products Universal footpeg kit, which is what I first used on the TY250B. Those footpegs then went onto my Majesty. I had the HEBO footpegs lying around so they went on the TY250B. Most modern trials footpegs fit those same U shaped brackets. The top mounting point for the 5mm plates is the frame lug left after you cut off the standard footpeg mounts. The bottom mounts use existing threaded holes in the frame cross tube (if your TY250 is a B model or later).
previous pseudonym feetupfun
Oldbiker
« Reply #31 on: November 23, 2008, 05:29:10 pm »
Feetup, I have a '74 TY250a. I don't remember the threaded holes near the pegs. Which later model pegs fit the brackets?
Offline David Lahey
« Reply #32 on: November 23, 2008, 07:58:16 pm »
To use the same idea for the brackets but on a TY250A, weld a disc of 6-8mm thickness in place of your TY250A frame tube cap and drill and tap a thread into it.
As far as other pegs go that fit standard TY250 mounts, I've never come across any. Most people just extend the standard TY pegs. I think there is a photo showing that idea posted in that same Trials Australia thread I put a link to above.
Oldbiker
« Reply #33 on: November 23, 2008, 10:33:13 pm »
ok I'll try the link and find the pic. I might pinch the welder off the neighbour and extend the pegs..
