Author Topic: pre 65 bsa rear engine plates need a patten  (Read 2660 times)
« on: November 03, 2008, 01:25:32 pm »
hi
i need to get a patten for bsa rear engine plates that bolt the gearbox to the frame.if some one could trace the outline of the plates it would be good.t then can fabricate the plates to suit burman box and ariel motor from the rear patten.
jim
ps
i have matchless steel gearbox plates if anyone needs a set
Offline pancho
Re: pre 65 bsa rear engine plates need a patten
« Reply #1 on: November 03, 2008, 06:25:21 pm »
before you put a gearbox in it get the burman box and see if you can throw it into orbit along with its crazy fragile spring box selector system and mainshaft with the same tensile strength as spaghetti ! every monday after a days racing at moorebank i was checking out ryans bike shop for more parts!!  cheers
