Author Topic: yss need help please  (Read 7695 times)
Offline caps 999
« on: October 29, 2008, 07:36:41 pm »
i need to know the cycel part number for your rear shocks for a rm125a
MUGEN power
Re: yss need help please
« Reply #1 on: October 29, 2008, 07:47:19 pm »
RM125a  shock absorber assy. rear (x2)  62100-41310 from Suzuki parts book. or did you want YSS part number Caps ? Yss would most likely supply that info to you. ;) Cheers Tim
PS I have parts book for RM125 M ,S, A, B  ;)
YSS
« Reply #2 on: October 29, 2008, 08:05:37 pm »
YSS does not have partnumbers for Classic shocks , they are made to order in Adelaide .
Cykel or Link will only have numbers to suit road registrable Suzukis in their application list .
Offline caps 999
« Reply #3 on: October 29, 2008, 08:49:21 pm »
ahh ok well i deal with cycel at work so im thinking it may be easier and cheaper to go through them
MUGEN power
YSS
« Reply #4 on: October 29, 2008, 08:59:26 pm »
Yes if you want street shocks , you will get a great deal through Cykel . Perhaps ring Marty or Andrew and  if they want to do it , by all means . VMX and VSX (Vintage Super Cross) ;D shocks I normally make to induvidual needs , thats not off  production due to spring clearances , eyelets ,off road  seals , valving etc.
Offline caps 999
« Reply #5 on: October 29, 2008, 09:02:26 pm »
haha im on good terms with marty or martaaa as hes known down here  :D i might have to call ya direct for these ones
MUGEN power
YSS
« Reply #6 on: October 29, 2008, 09:11:23 pm »
Yes you can call direct , there are also our factory trained service centres Mainly Maico and Husky Parts in Sydney area or ASR Racing  in Dromana near you.
Offline caps 999
« Reply #7 on: October 29, 2008, 09:17:06 pm »
how much would i be looking at for a set of rears for a rm125a ill be racing viper on it so ill nedd someting quite solid (air shocks are too expensive)
MUGEN power
YSS
« Reply #8 on: October 29, 2008, 09:25:33 pm »
Which type of shock do you want ?
E302T
Z 302TR
G302TR
G302TRC
Z 362TR  Prototype available only (not released till 09)
G362 TRC Prototype avalable only
Z 366TR
G 366TRC
G 366TRW   All those shocks can be made to suit . Confusing is it ?
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #9 on: October 29, 2008, 09:30:05 pm »
Dear Walter,
can you please put one of these link thingies on the bottom of your profile?
it'd make life so much easier... ;)
http://www.yss.co.th/index.php
and then, no more confusion.. :)
"flat bickie"
Offline caps 999
« Reply #10 on: October 29, 2008, 09:33:19 pm »
just a tad haha  :D
MUGEN power
YSS
« Reply #11 on: October 29, 2008, 09:33:41 pm »
I have one of those link thingis on my avatar .  www.yss-suspension.com   if you go to Bangkok you will not find any mention of VMX
YSS
« Reply #12 on: October 29, 2008, 09:35:21 pm »
Just click the green round ball .Try it  ;D
YSS
« Reply #13 on: October 29, 2008, 09:44:17 pm »
just a tad haha  :D
OK , do you need rebound adjustment  (R)  Threaded Preload (T) ,PIGGY back (G) , compression (C)
High Low speed (W)
    DIGIT 1 PRODUCT GROUP
F = FRONT TWIN SHOCK
V = FRONT MONO SHOCK
R = REAR TWIN SHOCK
M = REAR MONO SHOCK
T = REAR TWIN SCOOTER SHOCK
O = REAR MONO SCOOTER SHOCK
I = INNER TUBE
K = FRONT FORK
E = STEERING DAMPER
       DIGIT 2 PRODUCT TYPE
S = SINGLE TUBE HYDRAULIC SHOCK
D = DOUBLE TUBE HYDRAULIC SHOCK
Z = EMULSION GAS SHOCK ( E = ECO LINE )
G = EXTERNAL RESERVOIR PIGGY BACK GAS SHOCK ( C = ECO LINE )
X = EXTERNAL RESERVOIR ON HOSE GAS
SHOCK ( O = ECO LINE )
A = DIVIDED PISTON GAS SHOCK
B = INTERNAL BLADDER GAS SHOCK
    DIGIT 3-4-5 PISTON AND SHAFT
168 = PISTON 16 mm. + SHAFT 8 mm.
220 = PISTON 22 mm. + SHAFT 10 mm.
222 = PISTON 22 mm. + SHAFT 12 mm.
302 = PISTON 30 mm. + SHAFT 12 mm.
366 = PISTON 36 mm. + SHAFT 16 mm.
506 = PISTON 50 mm. + SHAFT 16 mm.
       DIGIT 6-7-8 LENGTH OF SHOCK
    DIGIT 9-10-11-12 FEATURE
P = STEP SPRING PRELOAD
T = THREAD SPRING PRELOAD
H = HYDRAULIC SPRING PRELOAD
R = REBOUND ADJUSTABLE
C = COMPRESSION ADJUSTABLE
W = HIGH-LOW SPEED COMPRESSION ADJUSTABLE
L = LENGTH ADJUSTABLE
       DIGIT 13-14 SPEC SHEET NUMBER
Offline caps 999
« Reply #14 on: October 29, 2008, 09:49:09 pm »
that sound about right to me
MUGEN power
