Author Topic: removing a shock resevoir  (Read 2975 times)
« on: October 26, 2008, 03:32:24 pm »
has anyone had experience with removing an alloy reservoir from an Ohlins piggyback shock? mine have very good annodizing and i dont want to mark them. Will they just unscrew with a strap type wrench tool similar to an oil filter removing tool for a car or road bike? i think there is one in the ohlins tool catalogue which i will probably get. would any heat be required? will this burn the annodizing or could i just heat the webbed alloy part to transfer heat to the thread in the alloy reservoir and not direct heat on the reservoir its self and not damage the finish?
« Last Edit: October 26, 2008, 03:34:51 pm by LWC3077 »
YSS
Re: removing a shock resevoir
« Reply #1 on: October 26, 2008, 04:38:19 pm »
We have a proper tool to assemble reservoirs , but there is never a need to remove them ,unless they are destroyed . I would imagine ,like YSS, Ohlins provides their service centres after satisfactory completion of schooling with a service centre kit , which would include all the tools needed. Have you done the school? Are you interested?
I run a school 4 x times per year in our factory for our international service centres. Graduations usually at the sportsbar :D
« Last Edit: October 26, 2008, 05:24:24 pm by YSS »
Offline paul
« Reply #2 on: October 26, 2008, 04:56:18 pm »
i gather you dont do it by correspondence then
YSS
« Reply #3 on: October 26, 2008, 05:25:19 pm »
Sorry its hands on  not correspondence ;D
Offline rocketfrog
« Reply #4 on: October 27, 2008, 08:39:02 am »
Where do you run the course?
YSS
« Reply #5 on: October 27, 2008, 08:50:03 am »
In our factory in Bangkok.  Which area do you live in . We are still looking for service centres in some areas.
Offline paul
« Reply #6 on: October 27, 2008, 08:53:48 am »
how do i qualify  ;D i dont drink  alcohol  can i pass with a degree in sasparalla
YSS
« Reply #7 on: October 27, 2008, 08:58:55 am »
I think we better present your application to the intire board first. :o
Offline paul
« Reply #8 on: October 27, 2008, 08:59:36 am »
whos on the board
