Author Topic: Different cases  (Read 2965 times)
Offline YUMASTEPSIDE
Different cases
« on: October 20, 2008, 11:18:56 pm »
I've seen pictures of Maico's with both of these styles of cases,and they've both been called '69 to '71 MC250..............PLEASE EXPLAIN ??????????
090
Re: Different cases
« Reply #1 on: October 21, 2008, 12:04:52 am »
Oval case is earlier and is eligible for pre 70, even if it is 71. Other style case is not. I think they change in 71 or 72( more likely).
Offline Maicojames
Re: Different cases
« Reply #2 on: October 21, 2008, 02:20:27 am »
New case designed in 70. Started seeing in 71. A bloke i know bought a 71 250 Sq new in 71-had both case designs on the floor then. I have also seen a 1970 Sq Barrel with new design cases-and original owner claims that's how it was delivered.
Interesting note-on Ake's 1972 bike he used the older round cases( narrower?)-must have made Maico real happy. ;D ;D
Life is suddenly very Monaro
Re: Different cases
« Reply #3 on: October 21, 2008, 09:57:54 am »
My '70 Maico 350 came out with the new sand cast cases but a mates 70 model 400 came with the old die cast 'round' outer cases. I think they were using up what they had left on the shelf. By '71 they were all sand cast 'new design' cases.
I've retro fitted the earlier covers for a more pre '70 look but changed back to the later sand cast ignition cover when I fitted PVL ignition. If anyone has a "narrow" early round die cast ignition cover I'm interested in buying it. The one I fitted is from a sixties round barrel and sticks out too much see bottom photo). They made a narrower version on '69-70 250s I believe. That's the one I want.
« Last Edit: October 21, 2008, 10:06:25 am by firko »
