Author Topic: PE400 fork oil???  (Read 2981 times)
Offline Grunter215
PE400 fork oil???
« on: October 18, 2008, 07:39:04 pm »
Just rebuilt forks so go to put oil in(no springs...) put in same amount each, take measurement from top tube to oil...20mm difference. Drain oil,repeat process...same What the ****!! .Is this a PE thing or a balls-up somewhere? I assume the measurement should be closer.Was told go by oil amount rather than measure. What ya reckon??
Re: PE400 fork oil???
« Reply #1 on: October 18, 2008, 07:52:09 pm »
fork tubes should be compressed and springs out  ......use the measure method lot easier  :)
« Reply #2 on: October 18, 2008, 08:21:26 pm »
yeah sounds like  trapped air. you gotta let them sit for a few minutes and bleed the air out by stroking them
Offline Grunter215
« Reply #3 on: October 18, 2008, 08:37:31 pm »
Yeah done the no springs/compressed tubes and worked tube up and down a few times incase of trapped air . has been sitting for about 2 hrs and still about 20-25mm difference. So aslong as measurement is same the oil volume wont really matter as much???
« Reply #4 on: October 18, 2008, 08:46:45 pm »
im not sure why there is that much difference. there shouldnt be that much diffference in the machining of the damper rods/fork tubes to create a 20-25mm difference. ???
Offline Grunter215
« Reply #5 on: October 18, 2008, 08:55:14 pm »
That was my thinking too. Might disassemble just to see. thanks guys
