Author Topic: quick help needed  (Read 27241 times)
Offline caps 999
Re: quick help needed
« Reply #75 on: December 02, 2008, 03:19:06 pm »
came out as spot on 56 but itll be fine at least ive got a barrell now
MUGEN power
« Reply #76 on: December 02, 2008, 03:27:16 pm »
you can get it re-sleeved back to STD
Offline caps 999
« Reply #77 on: December 02, 2008, 03:40:40 pm »
could but ill leave it as it is for the minute ;)
MUGEN power
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #78 on: December 02, 2008, 03:51:15 pm »
An RM125(A) is standard bore @ 56mm an RM125(B/C etc) is standard at 54mm are you rebuilding the engine as a B model?
Ban BLACK rims NOW
Offline caps 999
« Reply #79 on: December 02, 2008, 05:47:37 pm »
im rebuilding it as a b/a using a bottomend with b rod barrell piston and dg head
MUGEN power
Doc
« Reply #80 on: December 02, 2008, 09:28:01 pm »
even at 56mm it still gives you a couple of Suzuki oversizes or even more overbore options if you use the 0.25mm increment CR/MT125 pistons, set the lower locating pin to match the RM pistons and it's all go ;) I'm in the process of seeing if I can go to 61mm safely as I have alternatives starting at this size which theoreticaly bumps capacity to around 163cc. May need some headwork tho.... both the bike and for me to even consider trying it :D ;)
« Last Edit: December 02, 2008, 09:31:21 pm by Doc »
