Author Topic: quick help needed  (Read 27239 times)
Re: quick help needed
« Reply #45 on: October 25, 2008, 10:17:35 am »
I have bent flywheel tapers on cranks before after seizures at speed.It has definatly had a major seizure.You can have a major seize and not damage the bore.
Doc
« Reply #46 on: October 25, 2008, 01:05:35 pm »
yea, salvaged seized bores before with a little acid and a light hone when it was simple seizure but it appears all sides of the piston has been affected and the ammount of deep score damage seems a little unusual also Loz..as you say it could have happened more than once and no real history is known :-\ I dunno, all hypothetical but indeed a rare scenario..guess you're just lucky caps..usually I land on this type of thing ;)
« Last Edit: October 25, 2008, 01:07:10 pm by Doc »
Offline caps 999
« Reply #47 on: October 25, 2008, 05:55:47 pm »
got the roller stripped heres a pic
« Last Edit: October 25, 2008, 05:58:54 pm by caps 999 »
MUGEN power
« Reply #48 on: October 25, 2008, 07:49:39 pm »
yes original PE rear guards are well and truely into the rocking horse s##t category now. the only plastic repros out there are very poor to put it mildly and the few repro fibreglass ones around are usually not right either but i will admit there are a couple guys doing an OK job with the fiber glass ones. so original ones still in average to good condition that still have seom yellow colour left in them are quite sought after. Plastic restoration and repairs and plastic painting has come a long way in recent years and makes it worthwhile to hang onto parts like this.
« Last Edit: October 25, 2008, 08:03:32 pm by LWC3077 »
Doc
« Reply #49 on: October 25, 2008, 08:00:56 pm »
Looks an okay sorta roller caps..pretty original ;) what's the white Q sleeper in the background?  8)
Offline caps 999
« Reply #50 on: October 25, 2008, 10:48:26 pm »
shes not bad  ;D the old gts hq is stiitin there just what every garage needs makes a good anchor for the bike chains
MUGEN power
Offline caps 999
« Reply #51 on: October 25, 2008, 11:02:57 pm »
to mee the break in the crank looks more like a defect in the metal which has slowley progressed into s fracture
MUGEN power
Doc
« Reply #52 on: October 26, 2008, 07:46:22 am »
;D yeeees, I have the '53 4 door GTS Monaro..aka FJ Special sedan utilized as a mobile storage vessel that I'm soon to get stuck into and fix up...again 8)
The crank could have simply been a dud too..highly possible with mass production ;)
« Last Edit: October 26, 2008, 07:49:53 am by Doc »
Offline caps 999
« Reply #54 on: October 30, 2008, 04:54:28 pm »
i tried for that swing arm and ive given up now its bordering on drug money  >:( bloddy exchange rate
MUGEN power
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #55 on: October 30, 2008, 05:31:56 pm »
When it reaches those sort of prices it's probably cheaper to have one made  :-\
Ban BLACK rims NOW
Offline caps 999
« Reply #56 on: October 30, 2008, 08:34:28 pm »
would you know any one who makes them  ???
MUGEN power
Offline cyclegod
  • Sunny PERTH W.A
« Reply #57 on: October 30, 2008, 08:50:01 pm »
In Perth, I would take photo's of a period correct aluminium swingarm and my stock swingarm to Forbes and Mills engineering, he makes frames and such for drag racing so he knows how to build them strong. As long as what you have made looks correct you won't have any scrutineer probs either. It would be helpful if you asked that ebay seller for some dimensions just in case it's an inch or two longer and has different shock mount positions. If you ask some of your local dragbike racers where they get their bikes built it may give you a few leads.
Ban BLACK rims NOW
« Reply #58 on: October 30, 2008, 09:30:08 pm »
CG - if you go to Forbes and Mills be prepared for the wait???
Offline caps 999
« Reply #59 on: October 31, 2008, 09:45:27 am »
i might leave the swing arm till last
MUGEN power
