Author Topic: TS185 Ignition Swap  (Read 12733 times)
Re: TS185 Ignition Swap
« Reply #15 on: October 15, 2008, 08:13:19 pm »
so is that the 10 liter TS 250 ER tank? how well does it fit? do the forks hit? i have found it real hard to get 250ER parts, they are a rare model compared to the 185
Doc
« Reply #16 on: October 16, 2008, 05:00:23 am »
Pokey, footpegs yes, they be genuine Suzuki and the bracket is in the vise having extra welds laid cause you just know it'll snap off and hurt the ghoolies at some stage :o :D
Tankslapper, I tried an ER CDI on my RM once but it didn't work :( nothing ventured nothing gained and I gained the knowlege it won't work ::)
LWC, yes, a 10 litre TS250ER tank. It fits beautifully except on full lock yes, it does just touch the forks. Not enough to dent it and nothing a tiny dab of weld on the stops won't fix. Rear mount needs to be bent down a little but all lines up sweet.
It looks pretty crappy but all the good parts were raped off these donor bikes over the years hence why such a bitsa..for the price I paid for them they supplied my projects with cheap shockies, solid mount rear RM/TM hubs, front and rear backing plates, ignition coils, pivot bolts, handlebars, levers, cables and carbs etc. Never did I intend ever putting 1 back together until about 12 months ago when I started running out of space and scored a new crank and other useable TS bits. Easier to store a complete bike than it is to rack it for me ;)
« Last Edit: October 16, 2008, 05:13:52 am by Doc »
Doc
« Reply #17 on: October 22, 2008, 08:50:01 am »
getting there..about $20 invested so far but $30 should see it through ;) I've a couple of other jobs requiring immediate attention so this stop gap beasty will go on hold for a bit again now :)
« Last Edit: October 23, 2008, 09:56:57 am by Doc »
« Reply #18 on: January 02, 2009, 12:34:16 pm »
has anyone tryed one of these CDI's and can report on results? theres a rumour that these are the units to use but has anyone actually tryed it or seen it writen in a magazine? they use same ignition coil as 185. i wonder if the coil values on the stator will match/work with the RM CDI?
Part # = 32900-40221
Part Description = CDI UNIT ASSEMBLY
Model Count = 1
RM125-T 1980
Part # = 32900-40220
Model Count = 5
RM100N 1979
RM100T 1980
RM100X 1981
RM125-N 1979
RM125-T 1980
