Author Topic: TS185 Ignition Swap  (Read 12818 times)
Doc
TS185 Ignition Swap
« on: October 11, 2008, 12:00:40 am »
just a general question for electrical type guru's :P a TM250 stator and rotor on an '85 TS185 (same as '81 on or something), what cdi would one suggest? Early TS185 and so keeping with Kokusan? later stock ND TS185ER unit if compatable? or TM250 Kokusan or TM125 possibly. Any other ideas?..PE175 RM125 maybe? or lasty just try and see and if it goes bang I'll know it's all wrong :o ::)
« Last Edit: October 11, 2008, 12:04:59 am by Doc »
Re: TS185 Ignition Swap
« Reply #1 on: October 11, 2008, 12:41:16 am »
Guess the question should be what do you want the engine to do mate?
 If you want to use it as a a trail basher or if you want to stick it on a track and rev its ring out.
 if the later  one of those nice little units  from ane early yz80 are spose to be the ducks nuts.
 Have also heard that taking 1/3 of the weight off the stock flywheel gives a pretty good result. Thts for the pre75 1985s  and im buggered if I know about the ER series, perhaps an RM125 may be suited .
« Reply #2 on: October 11, 2008, 12:51:24 am »
Look at the length of the trigger bar on the rotor, that will speak volumes about the ignition.However  for a great stator rotor combo pocket bike external rotor are the go.You could even run with the diesel cdi as they still fire at the top of every stroke. Cost $60 complete delivered.
Doc
« Reply #3 on: October 11, 2008, 08:52:59 am »
Thanks Lozza but I wanted to stick with suzuki parts only on this. The idea crossed my mind last night as I inspected the TS185 bits and pieces I've collected. Can't see any point in having all these bits and not using them so I'll build a bike. I do have the proper flywheel/mag/CDI etc but I thought I'd try a TM250 ignition for size since I could.
 The TS185 shares the same flywheel as TS400 and TS400 share the same flywheel taper as TS250 so in all theory it should fit..and fit it does, a straight bolt up item! I want to try it and see how the motor responds before I decide which way I'll go with the bike..was thinking of building a nice low seat vinduro especially for my vertically challenged short arsed chassis ;)
Pokey, Bill reckons remove a third of the flywheel weight and the effect is very positive. The motor is stock as a rock and apart from a little port matching, deburring and polishing the only other internal mod will be some decent reeds. I don't know if I'll use the TM ignition but I've a curiosity that won't go away till I at least try it ;)
« Reply #4 on: October 11, 2008, 09:28:53 am »
i have a 1980 TS185 ER and it runs all kokusan electrics and my 1980 250 runs Nippon denson electrics. i think Cyclegod knows what to do here? it think a 79 or 1980 RM 125 CDI is the go.
Doc
« Reply #5 on: October 11, 2008, 12:00:46 pm »
I'll get this thing up and running as it is first and then I'll try these swaps. Don't suppose anyone's tried stuffing a 6 speed RM125/PE175 transmission into the TS185 cases?? This could well be a project for the spare bottom end :-\ I love this shit ;D
« Reply #6 on: October 11, 2008, 12:17:35 pm »
never though about that, but i dont have a 6 speed trans to try. ages ago i looked into fitting a higher top gear but it was hard work and i just pushed that idea to the side.
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #7 on: October 11, 2008, 12:26:05 pm »
TS185's use 15mm shafts and PE/RM's use 14mm shafts. If you replaced the gearbox bearings/seals with the correct inner diameter (52x20x14 instead of 52x20x15) it might work but it all depends on if the width is the same or if it can be shimmed to work plus there is the whole shift drum issue
Ban BLACK rims NOW
Doc
« Reply #8 on: October 11, 2008, 02:15:41 pm »
hmmm..interesting Mick, if I can find myself a donor PE175 bottom end I'll look into this idea a little more closely. cheers
Offline jimson
  • Sanctuary point N.S.W
« Reply #9 on: October 11, 2008, 07:41:29 pm »
Sorry to high jack the thread but while your talking 185 electrics if I have a coil and CDI unit off a RM250 81 model what would it do on a pre 75 TS 185 would it work  ::)  improve performance  :o  ? I thought about putting it on the budget racer.jimson
« Reply #10 on: October 12, 2008, 01:42:34 am »
Im thinking not a lot jimson. the 250 being a bigger cube thus not as big and as hard a revver as the smaller bores it will have a different map thus not as biased to fast accumulation of revs as say a 125  would be.
 suck it and see is prolly the best and then we will all know for sure
« Reply #11 on: October 12, 2008, 03:47:04 pm »
Still, you'd think that a 250MXer would be more rev-happy than a 185 traily?
Particularly when you consider that most trailys seem to have very conservative advance curves to allow for crappy and/or stale fuel.
Doc
« Reply #12 on: October 14, 2008, 11:51:15 pm »
Nathan get this, my RM400 runs the same CDI unit as the RM100C :-\ couldn't be more different yet it works for both. I just try 'em and see ;D
been slowly piecing together my TS 'Vinduro Special' :P another mega bitsa of course ::) TF185 top end and ignition, GT185 rear wheel, TS250 tank, PE175 seat, DR500 headlight, vinduro special tail light, GN250 shocks, there's more but I forget. Was going to fit the obligitory preston petty headlight numberplate and an itty RS250 speedo but when I did it looked shitty..correction..even shittier! :D once 100% together I'll rip it back to the bare frame again and tart it all up and it'll look just like all the others..kinda..I also modded B model exhaust shields as I don't like the look of the stock ER sidecovers so i guess it's not quite like all the others. 8)
« Last Edit: October 14, 2008, 11:55:37 pm by Doc »
« Reply #13 on: October 15, 2008, 07:44:22 pm »
Err. what about the footpegs Doc? Hope they are gonna be Suzuki ;D
Offline Tankslapper
    • Hydrosteer
« Reply #14 on: October 15, 2008, 07:44:49 pm »
I use ER185 CDI on all my CZ's. works a treat on the 250 and 400
