Author Topic: yamaha  (Read 3016 times)
Offline pancho
yamaha
« on: October 06, 2008, 05:29:19 pm »
i need an exhaust pipe to modify for my xt500 slider. basically i need just the engine pipe down to below the clutch cover. possibly one of an sx 500 might be better, the pipe on it is pretty horrible ---welded up out of bits & pieces i'd like to make a better one. also can any one suggest a piston that i could use on my rt1? it siezed it in the 25 lapper at the nepean 2 day & i now have 2 rti barrells that are already plus 40.since the class is over 250 cc, over size is not a problem, maybe some model 400 piston might do the job...any clues?...cheers wally.[sponsored by centerlink]
Re: yamaha
« Reply #1 on: October 06, 2008, 05:49:42 pm »
Piston port or reed-valve RT1?
I can point you in the direction of some reed-valve barrels if they help (I sold them to a mate just recently, and am assuming that he'd be willing to part with one of the four he got...).
Offline pancho
Re: yamaha
« Reply #2 on: October 06, 2008, 06:05:17 pm »
 my rti is pre 70 piston port and i therefore need a piston port to keep it eligible plus i rather fancy the thought of a few more cubes thanks for your reply ...wally.
Re: yamaha
« Reply #3 on: October 06, 2008, 07:05:42 pm »
wally
you can get the right piston for your non read valve 360rt1 to keep it pre 1970 i have 4 but they are all over 1mm oversize.ebay usa is were i got mine from.
Offline pancho
Re: yamaha
« Reply #5 on: October 07, 2008, 05:56:51 pm »
thanks for the info jim i have never used ebay but my daughter inlaw is an expert i'll get help,   cheers wally.
