Author Topic: piston  (Read 2262 times)
Offline DG 26
  • 250H 125D it490 looking for pre75bike
piston
« on: September 25, 2008, 06:36:15 pm »
Giday all
looking for a 3rd over size piston & rings for a yz125D
Bore size is 57.5mm
and a rod kit to  ;D
Offline Stewart Allen
CHEERS STEWART
Doing it to old things is fun
# 74 Heaven
IT490 Will be going one day soon
CR125M
SL175 bitza
IT250D needs work
CR250RE Not going as yet
YZ125F
Re: piston
« Reply #2 on: September 25, 2008, 10:35:20 pm »
Third over should be 56.75mm.
Yamaha go in 0.25mm increments, up to 1.00mm OS.
Wiseco do 1.50 and 2.00mm OS, giving you a couple of extra bites.
Be careful with how much you pay for Wiseco pistons from the states, and be doubly careful of buying genuine pistons without rings - the rings are stupidly expensive from your local Yamaha dealer (insert my oft-repeated whinge about IT250 rings that cost nearly as much as a whole Wiseco piston kit here).
Oh, and any YZ125C ~ N piston will work, although you might need to move the ring locating pin in some cases (at worst).
Yamaha gives them all different part numbers because they faffed around with the number of rings, the ring thicknesses, the intake cut-outs, etc - but they're all the same basic piston and they'll all make it go brroooom quite effectively.
Offline caps 999
Re: piston
« Reply #3 on: September 26, 2008, 08:54:56 pm »
i can get new wiseco kits if you want
MUGEN power
