Author Topic: indentification please.  (Read 4693 times)
« on: September 23, 2008, 10:51:30 pm »
I have just picked up a job lot of KTM's and need some help identifying them please. Here are the details and what I think they are: 1980 125GS VIN:003-45067, ENG:0-5002233. 1980 125GS: VIN:012-250992, ENG:0-5004895.
1981 250GS: VIN:012-26937, ENG:1-5413081. 1980 400GS: VIN: 010-22178, ENG:0-3603660.
There is also a couple of twin shock, water cooled 125's to come, 1981? Any help appreciated.
oz555ktm
Re: indentification please.
« Reply #1 on: September 24, 2008, 06:43:30 pm »
Ok
Fram No#  all start with 3 or 4 Numbers
thay tell you the Date and month thay were made . EG
the 1980 125 Vin starts with 003-#####
up to 1980 the first number was the year 0 =1980 and the 03 is the month.
the engine start with the Engine Family 500 first 125cc 501 2nd generathion 125 502 3rd and so on..
250cc eninge ID 540 = 250cc 541 2nd generathion
350cc up to 495 are the 560 Family
if you need more InFo you can Call Me and I will try to Held
you .Dennis 0411 598 818
« Last Edit: September 24, 2008, 11:36:43 pm by oz555ktm »
« Reply #2 on: September 24, 2008, 10:27:00 pm »
Thanks Dennis, I'm pretty sue I've soughted it out. The engine number for what I was told was a 400 is actually a 420. Whati thought was a 3 is a 5.
Chrs,
oz555ktm
« Reply #3 on: September 24, 2008, 11:35:27 pm »
The engine mite have 560 but dose it have any letters at the
end of the engine no# like a A or a B
 A = 350cc
 B = 390cc
Ktm Did put 350cc and 390 cc top ends on the 560 engine
560 did mean that it was a 420cc
560 = 420cc = 85mm piston
561 = 350cc = 77.5mm
562 = 390cc = 82mm
563 = 495cc = 92.5mm
« Reply #4 on: September 25, 2008, 09:41:41 pm »
Thanks again, it got the better of me so I took the head off for a look. 77.5mm piston = 350. Which engines have the same stroke, 350,390,400,420?
oz555ktm
« Reply #5 on: September 26, 2008, 06:18:23 pm »
All the same
The 560 engine are all the same But the 563 is bigger wear the
cylinder fit into the engine cases
so you can find a 390 or a 420 top end to put on your 350.
Did the engine No# have a Letter at the end of it ??????
« Last Edit: October 06, 2008, 03:38:19 pm by oz555ktm »
« Reply #6 on: September 26, 2008, 08:51:16 pm »
Thanks once again. No letter at the end of the engine number.
