Marque Remarks
Honda
CR125M CDI unit
Topic: CR125M CDI unit (Read 5788 times)
Stewart Allen
A-Grade
CR125M CDI unit
September 02, 2007, 09:25:33 pm »
Does anyone how to check or what the specs should be on a cdi unit? I have one that is dud, determined by substitution, I want to have a crack at fixing it. could only be diodes or transitors or stuff I suppose.
Any help appreciated.
CHEERS STEWART
Doing it to old things is fun
# 74 Heaven
IT490 Will be going one day soon
CR125M
SL175 bitza
IT250D needs work
CR250RE Not going as yet
YZ125F
dirttracker
C-Grade
Re: CR125M CDI unit
September 03, 2007, 06:40:29 am »
your best keeping clear of the 125m ignition i have 5 cdi boxes and everyone makes the bike different, i ended up putting a late model kx 125 unit on mine.
matt
Lozza
Re: CR125M CDI unit
September 03, 2007, 06:56:33 am »
Not like you to be divulging secrets Matt
No transistors but there will be a diode, a capacitor and an Silcon Controlled Rectifier(SCR or Thyristor) in there.
Should be able to see the cap with a analogue multi meter on the Ohm scale.Not sure about the SCR but.....
Good luck as you will need it.
dkupf
A-Grade
Kinka Beach Qld
Re: CR125M CDI unit
September 05, 2007, 09:37:28 am »
Matt. You wouldn't know what year the KX125 cdi box was?? :-\Darcy
Marque Remarks
Honda
CR125M CDI unit
