Author Topic: Ossa flywheel nut.  (Read 50018 times)
Offline olddirtbikes
Ossa flywheel nut.
« on: April 18, 2025, 09:39:20 pm »
  Hi Folks, can anyone tell me the correct way to undo the flywheel nut on a 1974 Ossa Phantom 250 please???
    Thanks, Alan
Offline PeterC
  • Bultaco MK 11
Re: Ossa flywheel nut.
« Reply #1 on: April 22, 2025, 08:27:02 am »
I assume it is a Femsa flywheel. You will need a flywheel holder too stop flywheel rotating, undo nut, remove washers andbthen use cirtect flywheel puller
Thumbs Up!
Offline Dungar Pilot
« Reply #2 on: April 22, 2025, 06:41:21 pm »
Hi Everyone,
It has been a while since working on an OSSA, my memory tells me there is a shock absorbing spring on the end of the crank? Most bikes have springs inside the clutch basket,  OSSA do things differently!
Photos would help you cause.
