Author Topic: 79 Suzuki Rm125 crank seal  (Read 84143 times)
Offline Tomas
« on: November 27, 2024, 07:16:40 am »
Helou
Just would like to ask Suzuki expetrs/addicts what right hand crank seal(79 Rm 125) can be used in place of the originĂ¡l suzuki item.  OriginĂ¡l suzuki has two spring but is no longer available from partzilla or cmsnl. Would a regular double lipped seal with only one spring work just fine?
Thank you
Offline sleepy
Re: 79 Suzuki Rm125 crank seal
« Reply #1 on: December 04, 2024, 11:02:52 am »
If my dimensions are correct the ignition side is 25x44x7 and according to CMSL is still available but the gearbox side is 29x47x8 is not available. I've just done a bit of a search at Bikes and Bits importers and they still list the gear side under part number 41.3-29002(Y) as available but the left side is not but a DT125/blaster seal at 25x44x8 is available under part No# 41.2-25331. These are Pro-X numbers. Bikes and bits are wholesale only so you will have trouble unless you have an account. Send me a PM if you want me to help.
Offline Tomas
« Reply #2 on: December 09, 2024, 08:16:49 am »
Thank you fo reply.  Ordered Pro X seals and also find an oil seal that is 29x47x7double lipped.  That is just a milimeter thiner than OEM.  Will try Pro X first and have the rest as back up. Sould hold ok.  Later suzuki used just a regular oil seals.  Nothing fancy
Offline Tomas
« Reply #3 on: December 31, 2024, 08:15:21 am »
Just an update.
Got oil seals.  Pro x seal looks identical to the regular 29x47x7 double lip seal only is 1mm thicker.  Have installed pro x and it holds ok after some riding.  No excesive smoking and hopefuly no leaks. Will se how long is it going to last :)
Offline Tomas
« Reply #4 on: June 05, 2025, 10:06:39 pm »
Have about 15 hours of riding on the replacement(non OEM) pro-x seal and it holds good. No white smoke or petrol in gear box :)
Offline PeterC
  • Bultaco MK 11
« Reply #5 on: June 06, 2025, 08:08:38 am »
Thanks for updating Tomas. Great outcome, persistence in locating parts pays off
Thumbs Up!
