Author Topic: 1976 RM 370A  (Read 41139 times)
Offline cwanedwiver
1976 RM 370A
« on: August 23, 2023, 05:51:58 pm »
Hi all,  can  anyone tell me if or when the Rm 370 kickstart went from fine spline to course spline, the part number for A&B kick shaft is the same, or has someone previously swapped it out with RM 400?? shaft
And is there another model clutch cover that will interchange/fit on the 370a mines knackered
And is their another model gear shift shaft you can use, no splines left on this one
Thanks for any help/advise
Offline jc17
Re: 1976 RM 370A
« Reply #1 on: October 26, 2025, 05:41:23 pm »
The new style shaft is 20mm diameter is installed on and after RM250-21024 and RM370-17949.
