Clubroom
Tech Talk
headlight for 76 KTM plastic nacelle
Topic: headlight for 76 KTM plastic nacelle (Read 12032 times)
ghostdancing
C-Grade
December 19, 2022, 02:38:32 am »
i have this shroud:
https://www.enduroklassiker.at/en/plastics-and-bodywork/7023-lichtmaske-ktm-gs6-modelle-1976-78.html
and i'm searching a lamp assembly to put inside the plastic; diameter it's 10cm..any help is appreciated!
LWC82PE
Superstar
Re: headlight for 76 KTM plastic nacelle
December 22, 2022, 01:04:42 pm »
UFO do the insert for that. Look up the insert for the UFO universal light assy. Enduro Klassiker should have it. Or try MD Racing products in UK. They are UFO importer.
ghostdancing
C-Grade
December 24, 2022, 05:32:39 am »
Hi Leith how are you? The ufo lamp assy its larger..i need a 100mm diameter lamp
LWC82PE
Superstar
December 31, 2022, 07:08:33 pm »
Ok thanks. Took a moment to figure out who you were. I am surprised the UFO is a different size though.. it looks smaller than the common 4 &1/2 (114mm) size insert that Preston Petty, PE's and TY Yamahas use. Maybe i confused it with M. Robert?
Clubroom
Tech Talk
