Author Topic: The Black Duck Returns!  (Read 19103 times)
Offline VERi
    • VERi
« on: August 17, 2022, 10:12:43 pm »
The next event on the VERi calendar is the Black Duck Vinduro at Campbelltown on Sunday 11 September.
Some of you might remember the original Black Duck Vinduro that was held at the same location 14 years ago.
The notorious gully section, and Fitzy drowning his Maico in a dam are still talked about around campfires to this day.
The course will start from the same bush property as 2008. The first 3km is freshly cut single trail. From there, the course takes riders along fairly well maintained bush tracks, then through a section that's been used for wood cutting and is a little more challenging. After that, it's more easy trails back to the start area with a short bit of the infamous gully thrown in. Total distance has not yet been finalised.
This is an easy ride suited to older bikes, so bring out those 1970s models you've been hiding!
Camping is available at the venue:
  • $10 per person per night
  • Portable toilets on site (no showers etc)
  • Bring your own everything
  • Space is limited so park sensibly
All bikes must be pre 1988 models, not too noisy and registered (full/rec/CPS). VERi does not accept unregistered vehicle permits.
Online entry will open soon via the VERi website.
Offline VERi
    • VERi
Re: The Black Duck Returns!
« Reply #1 on: August 25, 2022, 08:59:44 pm »
Online entry for the Black Duck Vinduro is now open:
http://www.verivinduro.com.au/134/black-duck-vinduro-2022
