Marque Remarks
Honda
CR250M'76 Fork caps
Topic: CR250M'76 Fork caps (Read 62934 times)
Paul Harris
C-Grade
CR250M'76 Fork caps
April 12, 2022, 11:00:52 am »
Not sure if this bike has standard fork caps - they don't appear to screw in and have right-angled air valves. Left side looks like it's leaking.
Slakewell
Slakewell Motordrome
Re: CR250M'76 Fork caps
April 12, 2022, 05:14:41 pm »
Many different forks caps fit different forks, If you have a thread measure device ( most are 1mm per cem ) and then measure outside dia, so for example most 35mm forks caps will screw into another set.
John Orchard
^^^ July 1984
April 13, 2022, 03:12:22 pm »
Does the cap have a hex head, DG caps maybe?
Paul Harris
C-Grade
April 21, 2022, 04:11:17 pm »
No John, They're circular - sit below the top of the fork and don't screw in - they spin freely but are definitely fixed.
Noel
Reply #4 on:
April 21, 2022, 06:26:00 pm »
Is it possible that there are 77 125 forks that have a ring clip that is held in place with a plate on top usually with a m6 bolt but maybe with the air cap. a photo would help. does it have leading axle ??
12,13,14, 26 in this schematic
https://images.cmsnl.com/img/partslists/honda-cr125m3-elsinore-1977-usa-front-fork-77-78_bighu0054f020401_5d1c.gif
Actually the 76 250 has a similar set up
https://www.cmsnl.com/honda-cr250m-elsinore-1976-usa_model594/seat-setspring_51460381305/
Last Edit: April 21, 2022, 06:36:29 pm by Noel
Paul Harris
C-Grade
Reply #5 on:
April 22, 2022, 11:35:39 am »
Thanks Noel - not leading axle. I've got photos but can't see how to post them on here?
Noel
Reply #6 on:
April 22, 2022, 04:04:54 pm »
https://images.cmsnl.com/img/partslists/honda-cr250m-elsinore-1976-usa-front-fork-m1-76_bighu0039f110401_4a19.gif
https://www.cmsnl.com/honda-cr250m-elsinore-1976-usa_model594/seatspring-upper_51454381003/
Last Edit: April 22, 2022, 04:07:50 pm by Noel
Paul Harris
C-Grade
Reply #7 on:
April 24, 2022, 08:58:42 am »
Thanks Noel, I'll attempt to get them apart. They're obviously aftermarket or modified.
Marque Remarks
Honda
CR250M'76 Fork caps
