Author Topic: TY 250A tank needed and fuel tap question for 70’s plastic tanks.  (Read 13271 times)
Offline crash n bern
Hi, no doubt being in the early stages of dementia, I destroyed my ty tank.  I don’t want to talk about it because it’s too embarrassing. So I’m in the market for one if anyone has one lying around that they have no use for. I know it’s a long shot.
At the moment I’ve fitted up a TL250 tank that works, but it’s sort of weird.
I also have a couple of plastic centre mount tanks for an Elsinore and one from a YZ  that that fit and look kinda okay on it. Now they just have a round hole for the fuel tap. There’s no screw holes for a normal tap and I doubt there’s enough meat to put some self tapping screws in to mount a normal tap without going all the way through. Unless that’s okay?.  So does anyone know what type of tap and where I could source one from?  I do recall back in the day seeing the taps where you had to feed the nut through from inside and they ran O rings to seal them.
Offline PeterC
  • Bultaco MK 11
Re: TY 250A tank needed and fuel tap question for 70’s plastic tanks.
« Reply #1 on: October 08, 2021, 07:28:01 am »
I have an old plastic aftermarket tank for a DT it uses a square lipped double sided plug like you would use in a firewall. Tanaka auger fuel tanks use the same plug.
Thumbs Up!
« Reply #2 on: October 08, 2021, 08:59:09 am »
Thanks Pete, I’ll look into it. At the moment I’ve ordered a mower/pit bike tap with a 10mm screw in fitting and a 10mm timber insert for woodworking. I thought I’d screw that into the tank with some Stagg joining paste and the fuel tap into that.
Offline Dungar Pilot
« Reply #3 on: October 08, 2021, 09:54:47 pm »
Hi Mate,
Just letting you know that I have a spare "A" model tank and you have a PM!
« Reply #4 on: October 12, 2021, 10:32:27 pm »
malcom smith desert tanks had push in groment/fuel taps and im sure i saw one at the bike shop i go to.think mcs do one
« Reply #5 on: October 12, 2021, 11:23:27 pm »
They are out there. Just search for tractor or mower tank tap, rubber grommet, fitting etc. I know Canams use this type too. Pretty sure RTR moto has them. https://rtrmoto.com/fuel-tanks-petcocks/ but i have seen them on ebay.
Malcolm smith tanks also used a threaded fitting type with an o-ring sandwiched between fitting and nut on the inside. You thread fitting in through filler hole on a wire.
Pretty sure there is a big thread on the XT500 forum about this here https://www.xt500.co/viewtopic.php?p=74921#p74921  it gets brought up often when people have these old plastic tanks and cant work out how to fit a tap.
https://www.plastic-mart.com/product/1040/1-4-brass-bulkhead-fitting-10897
https://www.fastenal.com/products/details/440113-131280;jsessionid=-l7JllQqS3I5hHbjlOUoEp-q.d36f637b-91a9-3b2b-9fa6-50af87272845
https://www.sonexaircraft.com/eshop/cart.php?target=product&product_id=16742&substring=oops+fitting
https://www.sonexaircraft.com/eshop/cart.php?target=product&product_id=16742&category_id=294
https://www.ebay.com/itm/Motion-Pro-Fuel-Valve-Petcock-1-4-NPT-1-4-Barb-Motorcycle-ATV/381145107872?epid=171269626&hash=item58be04cda0:g:7NQAAOSwhcJWO8m8
Oh also small aircraft parts suppliers have these sort of taps and fittings too.
Search 'bulkhead blind fuel tank fitting'
If you have a lathe you can make your own by drilling a hole through a big bolt. I started doing this with a  M14 bolt to accept an RL250 suzuki tap for a plastic tank. This is shown in the photo and named 'tap d' (black bolt not cut to length yet)
Tap A and B are original Malcolm Smith.
Will see if i have some photos to give you ideas.
« Last Edit: October 12, 2021, 11:42:00 pm by LWC82PE »
« Reply #6 on: October 15, 2021, 04:01:33 pm »
My aftermarket plastic tank just has a hole in the bottom for a tap, I have a Jikov tap with a male thread that goes through the hole with a nut on the inside to fasten it, I welded a little arm to the nut so that it would not rotate, I just put a soft alloy washer under the nut to have the tap pointed in the right direction once tightened to the correct tension.
