Clubroom
Tech Talk
powder coated hubs
Topic: powder coated hubs (Read 22683 times)
wato
Novice
powder coated hubs
October 05, 2021, 06:04:17 am »
Recently powder coated hubs on 83 xr 500.Do I need to strip coating where disk and sprocket are seated.
djr
C-Grade
Re: powder coated hubs
October 06, 2021, 04:15:20 am »
Probably a good idea to strip carefully the contact faces
some powder coating is so thick you wont get the sprocket / disc to fit without stripping anyway
to prevent corrosion maybe put a little copper grease on the faces
Momus
October 06, 2021, 05:19:45 pm »
Strip it 100%.
That area should be masked.
If you love it, lube it.
brent j
Darwin, NT. Suzuki tragic, RL250M TS90MX PE250B
October 06, 2021, 07:36:35 pm »
I powder coated a pair of hubs years ago.
I masked the sprocket and disc mounting surfaces but found the powder coating cracked and flaked away where the spokes pulled against the mounting holes in the hub.
wato
Novice
October 06, 2021, 08:05:15 pm »
Thanks for replies .Will strip
bazza
October 07, 2021, 12:20:19 pm »
Paint and bake in oven
Clubroom
Tech Talk
powder coated hubs
