Clubroom
General Discussion
xr500 re electrical testing specs wanted.
Topic: xr500 re electrical testing specs wanted. (Read 7756 times)
ELC hunter
B-Grade
May 03, 2021, 03:21:16 pm »
Hi anyone know the test values for 83/84 xr500 for stator, coil, and that transducer on the right side thanks the bike has thrown a chain and cut the wiring even after repair no spark cheers ELC hunter.
sleepy
Re: xr500 re electrical testing specs wanted.
May 03, 2021, 04:12:29 pm »
I've got a shop manual here for XL400 - 500R, 1982 is the date on the front cover.
AC generator exciter coil is 50-200 Ohms (Black/red wire to ground)and the Pulse generator is 510-570 Ohms (Blue/yellow and Green/white wires)
ELC hunter
B-Grade
May 04, 2021, 09:37:37 am »
The problem is that the wires all look black in colour having trouble finding trace colours
sleepy
May 05, 2021, 08:58:19 am »
That can be a problem. The other wires coming out are the Charge coil and the Lamp coil both are listed at 0.2- 1 Ohm. The Charge coil connects to Pink and yellow wires. The Lamp coil is the white/yellow wire and it tests back to ground.
To identify you will need to check between wires and check to ground.
If you PM me an Email address I can send a scan of the wiring diagram with the resistances drawn on.
Clubroom
General Discussion
