Author Topic: KTM front brake assembly - twin leading shoe  (Read 43673 times)
Offline PEZBerq
  • Brisbane
« on: April 30, 2021, 06:24:50 pm »
Hi KTM gurus!
Do the larger KTM 250 or 420/495 bikes run a bigger front diameter twin lead front brake drum compared to the 125s? I have what I believe is a 125 front brake and it is only a tiny 130mm drum diameter approx. I expect the larger bikes run a bigger brake? Can you tell me what size drum diameter the 250 or 420/495 use? Would it be 160mm?
« Last Edit: May 01, 2021, 10:15:49 am by PEZBerq »
Offline ozktm151
Re: KTM front brake assembly - twin leading shoe
« Reply #1 on: May 07, 2021, 05:24:10 pm »
Hey PEZ the short answer is no. Same twin leader for all bikes. Someone sometime told me it was a copy of the Yammie one. Have never used one myself as I went the disc way on my 85 250. I guess it is how, why and where you ride as to your preference in brakes. Sorry for the bad news, hope you come up with a satisfactory solution. Cheers Bill
Offline PEZBerq
  • Brisbane
« Reply #2 on: June 21, 2021, 07:34:49 pm »
Sorry for the late reply. Thanks ozktm for the confirmation. I hear the KTM twin leading brakes worked quite well and could stop the 495 monster so should be OK for my speed 8)
