Marque Remarks
Honda
CR250M rear sprocket WANTED
Topic: CR250M rear sprocket WANTED (Read 65448 times)
g465b
B-Grade
February 27, 2021, 01:34:00 pm »
CR250 M REAR sprocket WANTED fits 1975 and 1976 model it is a dished sprocket 47 , 49 and 51 teeth were available
6 bolt to hub 111mm center hole and approx 17mm of offset same as MR250 enduro of 1975. wanting to buy a NOS sprocket.
cheers G.
bazza
Re: CR250M rear sprocket WANTED
February 28, 2021, 12:10:48 pm »
Got a steel one off evil bay, curved. Other wise you need a spacer to use with a early 250M sprocket
Once you go black you will never go back - allblacks
Embrace patina
bazza
February 28, 2021, 06:13:56 pm »
Part number 381 NOT 395 (395 MR250) Nos alloy one in michigan but$279 US. Company called NPN
Embrace patina
Paul Harris
C-Grade
March 09, 2022, 04:25:53 pm »
Hey
Did you have any luck? I'm looking for the same thing.
Paul Harris
C-Grade
Reply #4 on:
April 21, 2022, 04:13:32 pm »
I'm getting a spacer made up to run flat sprocket with counter-sunk bolts.
bazza
Reply #5 on:
April 23, 2022, 08:07:31 am »
DC plastics do a sprocket and spacer for sale
Embrace patina
Paul Harris
C-Grade
Reply #6 on:
April 24, 2022, 09:03:16 am »
Thanks Bazza - out of stock though. Sprocket Specialists not doing them anymore.
Paul Harris
C-Grade
Reply #7 on:
October 01, 2022, 10:09:17 pm »
I've had an adapter machined for a flat sprocket - great job, looks neat and works a treat.
Marque Remarks
Honda
