Author Topic: RM 500 rear wheel .  (Read 7822 times)
Offline Husky500evo
RM 500 rear wheel .
« on: October 08, 2020, 09:48:42 am »
RM 500 rear wheel and brake backing plate wanted . Even a hub would do .
Also chasing an RM 500 cylinder head .
Offline BAHNZY
Re: RM 500 rear wheel .
« Reply #1 on: October 20, 2020, 01:20:48 pm »
Does the 500 share the same rear hub as a 250?
Rod (BAHNZY) Bahn
Offline Husky500evo
« Reply #2 on: October 22, 2020, 11:46:43 am »
I believe that they are slightly different, but I think that a 250 hub would do the job for me . An RM500 guru told that the 500 hub is a bit more beefed up where the spokes go through . The OEM RM500 wheel has a 2.5” wide rim , where I think that the 250 is around 2.15” wide . The bike I am planning to use it on , is an ‘85 RM250 frame fitted with an RM500 motor , so I will probably look at getting a 2.5” gold anodised rim laced up to the rear wheel .
