Author Topic: Metal Cutting Saws  (Read 9099 times)
Offline skypig
Metal Cutting Saws
« on: December 17, 2019, 11:10:44 am »
Hi experts.
Something I’ve wanted for a long time.
Thinking of buying a “DeWALT 355MM 2200W Cold Cut-Off Saw“ for Xmas. (Nearly A$900)
It claims it is “ designed for cutting ferrous & non-ferrous metals without producing sparks or heat”
Sounds like what I want. I’d like to cut alloy and steel.
However, past research indicted that Steel needed slow speed (Some “lubricated” saws run under 100rpm I think), while Al required a faster speed.
The DeWalt runs at 1300rpm, comes with a 66 tooth blade.
Comments/Info.
Offline sleepy
Re: Metal Cutting Saws
« Reply #1 on: December 17, 2019, 06:56:07 pm »
I have an old cold saw, think it's an Omes and it runs quite slow with a coolant supply. The difference with this more modern saw is the Tungsten Carbide blade which is happy to cut at 4 time the speed of the old High Speed steel blade. From the youtube I watched you will still get red hot chips/swarf coming off it but it looked a lot less damaging than the sparks that come off an abrasive cut saw.
If I was in the market for a new cut off saw I would probably think about one of those or similar. There is a Evolution brand out there that get a good review as the base is much more sturdy.
Offline Momus
« Reply #2 on: December 17, 2019, 09:38:44 pm »
Buy the Bosch equivalent at well under half the price.
If you want a true do-all machine you really need a horizontal band saw.
The chop saws are ok for rhs and aluminium but not really suitable for solid, harder round steel.
I use a 300mm Brobo cold saw with a fine tool steel cutter for RHS and sometimes cut ally plate and bar with a coarser blade.
For fast work in Al. I'd use a high speed chop saw with a triple chip blade and if cutting steel RHS swap with a narrow abrasive blade. This will work very well for docking timber.
For steel bar in larger diameters horizontal, cooled, band saw is the go.
« Last Edit: December 19, 2019, 04:08:23 am by Momus »
If you love it, lube it.
Offline skypig
« Reply #3 on: December 18, 2019, 09:09:09 am »
Thanks very much. The info is appreciated.
It’s looking like a horizontal band saw will be “the go”, but a bit big for my bulging shed.
New shed in the works.
