Author Topic: 38 mm forks  (Read 36257 times)
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
38 mm forks
« on: May 15, 2019, 12:37:00 pm »
Would anyone know when the 38 mm forks where first fitted . Year and hopefully month . Thanks .
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
Offline sleepy
Re: 38 mm forks
« Reply #1 on: May 15, 2019, 04:02:56 pm »
Got a Maico owner manual here from Nov 1975 that list 38mm forks.
Offline Wasp
    • Suspensionshop
Re: 38 mm forks
« Reply #2 on: May 17, 2019, 08:51:19 am »
Thanks , what years where the forks with  the external springs ?
Offline sleepy
Re: 38 mm forks
« Reply #3 on: May 17, 2019, 09:25:50 am »
The last external spring forks where on the 1974 4 speed models. The first 5 speed models had internal springs but I'm not sure on the size. Most likely 38mm from what I can see from spares parts info. That would mean they where available early 75.
Offline sleepy
Re: 38 mm forks
« Reply #4 on: May 17, 2019, 09:39:02 am »
I should add that the external spring forks are 36mm. The 38mm went up to 1979 and in 80 we got the 42mm.
Offline Wasp
    • Suspensionshop
Re: 38 mm forks
« Reply #5 on: May 17, 2019, 10:43:01 am »
Thanks , So we can conclude 38 mm ( actually 37.80 )  1975 -1979 . I will make a batch of fork springs  31.5 mm OD by 560 mm long . This will give the option to run the PD valves or a spacer .
Offline sleepy
Re: 38 mm forks
« Reply #6 on: May 17, 2019, 11:18:50 am »
The travel of the forks changed across the years. 76 had 220mm, 77 had 245mm and 78 had 254mm. Not sure on the 75 travel.
Offline Wasp
    • Suspensionshop
Re: 38 mm forks
« Reply #7 on: May 17, 2019, 11:50:37 am »
Thanks Sleepy for that valuable info . I have designed the springs to take 260 mm travel incl Preload  and PD Valve . People without the Valve will have to use a 18 mm spacer to make up for it .
