Clubroom
Tech Talk
Hi -Low speed suspension for VMX
Topic: Hi -Low speed suspension for VMX (Read 8141 times)
Wasp
A-Grade
Your Suspension Solution since 1989
April 16, 2019, 04:11:09 pm »
Just finished the high low speed 3D housings for the long travel shocks . You can sway the reservoir 360 degrees , that will make it fit almost anything . The can also be extended 10 or 20 if needed .At the same time I enlarged the reservoir by 20% volume to house a bigger bladder.
https://store.suspensionshop.org/maico/mx/1980-1989/shfrtwhp-ma81-mc490-81-82-mc490-hyperpro-shock-adjustable-fixed-reservoir-1-pair-black.html
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
topari
B-Grade
Re: Hi -Low speed suspension for VMX
April 16, 2019, 10:48:03 pm »
Are these Shocks your own design?
topari
1979 IT400F, 1984 kdx200
TT5 Matt
April 16, 2019, 11:34:08 pm »
the link doesn't work
Wasp
A-Grade
April 17, 2019, 10:28:26 am »
Yes , the 362 series is my design . A hardy workhorse for reasonable money thanks to low overhead costs .
topari
B-Grade
Reply #4 on:
April 17, 2019, 10:36:53 am »
The link points to TYPE 467/367 FULL ADJUSTABLE SHOCK
topari
Wasp
A-Grade
Reply #5 on:
April 17, 2019, 12:46:19 pm »
Thanks for pointing it out . Yes the site needs to be adjusted as well .
Clubroom
Tech Talk
