Marque Remarks
Suzuki
RM 400N shocks resto
Topic: RM 400N shocks resto (Read 8844 times)
Tony Two Times
C-Grade
March 29, 2019, 09:59:39 am »
So are the original remote resovoir shocks from the late 70's models worth rebuilding and re-using?
Would like to stay original but wary of spending on rebuild vs replace.
T2X
#66 - Fat Snail Racing.
Momus
Re: RM 400N shocks resto
March 29, 2019, 09:22:23 pm »
Yes and yes. Engineers rebuild with machining and mucking around required though.
If you love it, lube it.
Tomas
A-Grade
March 30, 2019, 01:35:54 am »
Did a 125N set a while ago. Used ohlins seal heads and 12 mm CrMo hardchromed shafts + ohlins rod ends 10mm longer than original. You will loose about 10mm of stroke. I also cut the reservoirs open and made aluminium caps with a valve.
Or you can just change oil and keep them original. I am using 5w and they work fine for my riding
Tony Two Times
C-Grade
March 30, 2019, 08:33:14 am »
Excellent thanks. Will take them to Rad for a rebuild.
Marque Remarks
Suzuki
