Author Topic: M Oil in 1970s: Who made it?  (Read 17648 times)
Offline Berwick Boy
« on: March 26, 2019, 09:54:12 am »
Can anyone help me  - trying to find an image of M Oil container, but I don't know anything about it.  Can't get a hit on Google ...
I wonder who was the manufacturer.  Was there more than one company?
Re: M Oil in 1970s: Who made it?
« Reply #1 on: March 26, 2019, 10:03:21 am »
Castrol. Used for methanol engines.
Offline PeterC
  • Bultaco MK 11
« Reply #2 on: March 26, 2019, 11:39:59 am »
Correct there was Castrol M I think for 4 stroke alkyl and R30 & 40
Thumbs Up!
« Reply #3 on: March 26, 2019, 01:04:38 pm »
Shell Super M castor-base racing oil.
Offline Berwick Boy
« Reply #4 on: March 26, 2019, 03:30:53 pm »
Thank you all    :)
« Reply #5 on: March 26, 2019, 04:46:27 pm »
« Last Edit: March 26, 2019, 04:51:40 pm by Hoony »
Offline huskibul
« Reply #6 on: March 26, 2019, 05:19:01 pm »
  Shell M  (castor base) early 70's even sweeter smell than castrol r me think ! ;)
« Reply #7 on: March 26, 2019, 10:23:37 pm »
after gumming up the rings on my 79 cr250 with castrol r30 a mate with an it175 and an 2 valve jawa speedway bike said to use shell m so I used it on the cr and then later on my jawa 4 valve long tracker with no gumming or any other problems,also easy to clean off with degreaser
Offline huskibul
« Reply #8 on: March 27, 2019, 02:24:41 pm »
  yeah it was good tt5matt we use to run it in a  tm 125L's CCI -no problem seemed thinner than R30 from memory
« Reply #9 on: March 27, 2019, 04:41:11 pm »
I remember my Suz TM125 owners manual suggested either Castrol R30 or Shell Racing M castor oil.
Shell also sells Methanol as Shell M also.
« Reply #10 on: March 27, 2019, 05:10:34 pm »
The Shell methanol is called "Shell A"
R30 was the oil of choice back then for the petrol 2 strokes but you can't use Castrol M with petrol as it doesn't mix. The Shell M was a blended castor base oil that would mix with either methanol or pertol. Had a big drum of the Shell M and used it in my PE175 but it was quite a dirty oil with lots of carbon build up.
Offline OverTheHill
« Reply #11 on: March 29, 2019, 10:17:37 pm »
I used to use Castrol MSSR mixed in Alky in my YZ125's in the late "70's & 125G in 1980. The Alky was called Shell Racing Spirit Special. Purple in color & if it it escaped the tank cap it cooled ya nuts instead of stinging like petrol [did i say that] Back in the B33 [BSA] days on Alky--in the motor i used Shell Super Heavy which by memory was like Castrol R but thicker. No wonder the old girl was hard to kick over on frosty days on first start with flywheels dragging on what was lying in the bottom. On my DT2 on Alky i ran the oil through the pump--not sure now if it was MSSR or shell M if that's like Casrol R, but the yellow gold anodized Yamaha slide used to stick open on Alky so premixed it & was ok--should have done that in the first place. Actually come to think i used the pump initially as premixing it used to go cloudy & separate on cold days till some said add something--acetone maybe. Too long ago now but Bring back Those Days lol.
