Author Topic: here we go again different set  (Read 5759 times)
Offline jimson
  • Sanctuary point N.S.W
« on: September 07, 2008, 06:19:17 pm »
this is another pair Im unsure about these at the top are 29mm and the fork shaft is 33mm and it also has a brake stay arm on it what do you think?  :-\
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: here we go again different set
« Reply #1 on: September 07, 2008, 06:54:47 pm »
They look Suzuki to me, perhaps early TM250/400 they used a torque arm to the brake backing plate. They look to be in fairly nice shape whatever they are.
Ban BLACK rims NOW
Offline crs-and-rms
  • heaven 23
« Reply #2 on: September 07, 2008, 07:14:22 pm »
the tm didnt have the double attachment where the brake arm bolted on are  the forks 29 mm where they fit into the tripple clamps ? if they are i might be keen to buy them  for the tm 125 i got from you
Doc
« Reply #3 on: September 08, 2008, 06:30:54 am »
Jimson, these particular forks look like early TY250 jobs. I 'think' they're 34mm at the seals. Could these measure out at 34mm perhaps and not 33mm??
late edit..nope I was wrong! The brake stay mount is in the wrong place :-\ my new guess is '73 CT1 175 Yam  ;)
« Last Edit: September 08, 2008, 07:07:57 am by Doc »
Offline jimson
« Reply #4 on: September 10, 2008, 08:12:13 pm »
Doc I don't think there Yammie mate. I wish some one out there had a sure answer   :'( jimson
Offline matcho mick
    • Moto Tumbi
« Reply #5 on: September 11, 2008, 11:05:09 pm »
i say they're early 70's honda!,SL/CL250/350??,definately the brake anchor arrangement!,locking plates a givaway,someones just got creative with the latheworks my guess, :P
« Reply #6 on: September 11, 2008, 11:34:16 pm »
I think they're Hatta forks from a Kawasaki of some sort. F11 possibly?
« Last Edit: September 11, 2008, 11:46:50 pm by firko »
Rosco400
« Reply #7 on: September 12, 2008, 06:57:23 am »
I agree with M
ick, early Honda SL
Doc
« Reply #8 on: September 12, 2008, 06:20:43 pm »
The regular F11 forks have a more oval outa lower casing, no machined area and no brake stay, the 350 hatta I have and have seen had the brake torque arm mount but also the 3 way axle setup so I don't think either of those. SL/CL350 is sounding like a good chance too and I'm kinda of now thinking the machining is not factory ;)
basil44
« Reply #9 on: September 12, 2008, 07:14:45 pm »
I recken early Yamaha roadracer,maybe TA,TD,TR,TZ.Who would go to the trouble of machining the staunchions and not taking off the forkleg guard mounts.Yamaha had machined  staunchions on early YZs and MX250B,MX400Bs.Look outside the square big ears.Cheers.
« Reply #10 on: September 12, 2008, 07:35:59 pm »
Nope, completely different - had screw on seal holders and steel sliders. Not the later RD style either.
Many forks had the 'waisted' staunchions between the triples. As much for style as weight savings ::).
If CL350's had the waist they would be the best bet; everything else fits IIRC.
« Reply #11 on: September 12, 2008, 07:40:33 pm »
early TS 250 shitters
« Reply #12 on: September 13, 2008, 11:23:38 am »
Honda CL350 not later SL350  >>> I have a pair of each here... both labeled, <<<<   SL350 do not have the extra stay mount due to smaller twin leader brake I assume and not the stepped in bit. OK Next item please,  Cheers Tim   (Got to watch my grammer! that above is terrible  :D)
« Last Edit: September 13, 2008, 11:26:26 am by Tim754 »
