Author Topic: Yamaha dt1 250 none reed valve pre 70  (Read 34173 times)
Offline jimson
  • Sanctuary point N.S.W
« on: September 25, 2018, 07:54:36 pm »
G'day viewers I'm selling this Dt1 250 and a heap of parts
$2500 ono bike is located in Sanctuary Point NSW about 25 minutes from Nowra
« Last Edit: November 13, 2018, 06:38:28 pm by jimson »
Offline jimson
Re: Yamaha dt1 250 none reed valve pre 70
« Reply #1 on: September 25, 2018, 07:56:29 pm »
Offline jimson
« Reply #2 on: September 25, 2018, 07:58:12 pm »
Offline jimson
« Reply #3 on: September 25, 2018, 07:59:54 pm »
« Reply #4 on: September 25, 2018, 08:07:07 pm »
Nice entry into pre 70  jimson .
Offline jimson
« Reply #5 on: September 25, 2018, 08:07:35 pm »
As you can see its a job lot. The frame hanging on the wall  has been professionally modified to lower the engine and it has surface rust only. The spare engines are all reed valve but the engine in the bike is pre reed valve. I've had the bike since around 2004 its spent most of that time locked up in a shed. When I purchased the bike, I was told it was built by a 2 stroke specialist back in the 70s called Jimmy Smithurst. He had a engineering company in Taren point NSW
Offline jimson
« Reply #6 on: September 25, 2018, 08:12:18 pm »
Thanks Iain, it's sad to let it go. I've just not done it justice, it needs to get out and stretch its legs. jimson
Offline jimson
« Reply #7 on: September 25, 2018, 08:15:21 pm »
I need to dig out more parts and will post more pic's as I find more. There is enough parts to build another  Dt1 250...
Offline jimson
« Reply #8 on: September 27, 2018, 05:45:45 pm »
Original fuel tank, it needs a little tlc but appears clean inside. The seat is off a smaller earlier model but would fit with some fabrication.
Offline jimson
« Reply #9 on: October 01, 2018, 09:08:45 pm »
Just bumping this along...  :-\ jimson
Offline jimson
« Reply #10 on: October 02, 2018, 06:44:34 pm »
I throw these in the sale as well & I'm still looking for more parts that will be included.  Thanks jimson
« Reply #11 on: October 02, 2018, 10:44:02 pm »
Just a note The front hub would have to be a full width one for pre 70 legal .
Offline jimson
« Reply #12 on: October 04, 2018, 09:01:32 pm »
G'day Iain, I've got the original wheel that will go with the sale. jimson
Offline jimson
« Reply #13 on: October 04, 2018, 09:08:23 pm »
Offline jimson
« Reply #14 on: October 04, 2018, 09:09:49 pm »
