Author Topic: KX 450, KX 400 & KX A5 new and used parts for sale  (Read 3791 times)
Offline Kel
« on: September 05, 2018, 02:56:57 pm »
Hi Guys, I am relisting some excess Kawasaki bits that I no longer need, some have been sold and are marked as such. I can email detailed pictures of parts if needed, ( some pictures were posted on 17-09-2016 and still can be viewed on here),don't be afraid to haggle on price.
Thanks for looking and happy hunting.
NEW ( NOS ) KX 450 parts. KX 400 Parts. KX A5 parts. Check part numbers on the Kawasaki parts web page for possible other bikes that parts may and will fit. I have experienced that some parts that are interchangeable with other bikes are not necessarily stated on this web page, so be mindful of this and please buy at your own discretion.  Web page  to use is partzilla.com
The parts prices will be based on Partzilla original prices, we can negotiate from there.
ALL PARTS ARE NEW (NOS ) UNLESS OTHERWISE STATED.
ALL LISTED PRICES ARE PER ITEM
Postage at Buyers expense
Contact me via email or Pm for any further information that you may need.
Thanks and happy hunting.
Kel.
NEW GEARS  all 450 & 400 same . Some A5 are same.
4th gear Output shaft   19 teeth   13135-023      2 of              $100
4th gear Output shaft   19 teeth   13135-034      1 of              $100
Top Gear drive shaft  18 teeth  13136-045          2 of              $90
Primary gear drive shaft  23 teeth  13121-024     1 of              $130
Low gear output shaft  26 teeth  13129-049        1 of              $85
Top gear output shaft  17 teeth  13137-028        1 of              $100
Pinion gear Clutch / kick 16 teeth 13075-011      1 of     A5      $95
2nd gear Drive shaft  16 teeth 13129-114           1 of     A5     $85
2nd gear drive shaft  13 teeth  13130-035          1 of               $85
Kick start Idler Gear  31 teeth  13073-010          1 of               $95
Top gear drive shaft  24 teeth  13129-1028        1 of       A5     $120
Kick start gear 25 teeth   13068-029                  2 of                $60
Change drum  13141-037                                  1 of                $120
Change drum  13141-042                                  1 of                $120
Change Fork  low  13140-055                            3 of                $65
Change Fork  2nd & 3rd  13140-056                   4 of                $65
Change Fork  4th & top  13140-057                    3 of                $65
Kick start shaft   13066-1003                             1 of      A5      $86
Kick start guide  13206-009                               5 of                $8
Stopper    13072-014                                         5 of               $8
Holder  13142-014                                           10 of               $14
Leaver assembly gear change 13236-005            3 of                $7
gear change Leaver assembly  13161-031           4 of                $45
NEW KX 450 parts. KX 400 Parts & KX A5 parts.
Clutch leaver     13103-022    A5, 450 400          2 of             $26
Spacer washer 92027-045 / 92027-2908            1 of             $4
Clutch shaft  13106-006  A5, 450 & 400             2 of             $33
Points / CDI cover  14031-065                           2 of             $130
Plug / dip stick 16115-019  450, 400 A5             3 of             $15
Suspension bits
Triple Clamps Complete:
44039-059 = $115,
44038-007=$130,
44041-065 = $30,
44052-009 = $125
Total = $400
Triple clamp bottom  44038-007                                 1 of          $130
Steering head washer 44043-052 450, 400, A5            1 of          $10
Left hand Fork outer 44005-056                                  4 of          $150
Left hand fork outer leg  44005-051                             1 of          $150
Inner fork tube  44013-048                                         2 of          $130
Fork cylinder assembly  44022-022                              1 of          $77
Fork cylinder assembly  44022-015                              1 of          $70
Fork spring  44026-056   445 long, 25 od, 15 Id           1 of           $30
Fork spring    540 long, 29 od, 21 Id                            4 of           $30
Piston for forks  44018-006                                         5 of           $20
Ring stoppers circlip for forks  44020-003                   30 of           $3
Carbies
Mikuni  905 incomplete , no bowl    New                1 of            $100
Carby springs  16006-028  kx 400                        2 of            $5
Wheels
Rear brake cam 42020-013                                  2 of            $35
Rear brake cam 41050-014                                  2 of            $35
Axle 41068-047  235 long, 12ml                           3 of            $30
Axle rear  42031-030                                           3 of            $30
Axle 41068-041  220 x 12                                                        1 of       $30
Axle 41068-1006    200 x 15                                                    1 of       $45
Collar  41039-023     450, 400, A5                                            1 of       $25
Collar spacer front wheel  41069-023  A5                                  5 of        $20
Collar spacer rear wheel  42010-024     A5                                1 of        $30
DID joining link 92058-1002                    A5                             1 of        $10
Guide  57001-169        2 of        $15
Guide front brake  54030-009                                                   2 of        $10
Guide front brake  54030-010                                                   2 of        $10
Bolt chrome headstock  44041-059 450, 400, A5                      10 of        $5
Adjuster chain 33041-002                 A5                                    1 of        $20
A5 front wheel spacer                                                               1 of        $20
Bar foot rest  l/h    34028-021                                                 17 of        $25
Spokes
41027-067 rear inner                                                            30 of    $3.00 each
41028-067 rear outer                                                            40 of    $3.00 each
41027-061 Front inner                                                           40 of   $3.00 each
41028-061 Front inner                                                           50 of   $3.00 each
41028-062 Front inner                                                           60 of   $3.00 each
Front sprocket  13144-1006 13 t A5                                         1 of    $45
Front sprocket  13144-051    14t                                              4 of    $45
Muffler bracket  18024-021                                                      5 of    $25
Base  5701-341        1 of    $15
Throttle cable  54012-106                                                       5 of       $40
Throttle cable, fit gunner gaser 54005-075                               1 of       $40
Front brake cable  54005-075                                                 2 of       $50
Grips set 46075-023 & 46019-032                       1 set       $21 & $54  total $75
Grip throtle assembly 46019-032                                            1 of        $55
Throtle 46023-015 fits 46019-032                                          1 of         $35
Throttle bottom  46023-020                                                   1 of         $35
Throttle top 46023-020?                                                        1 of         $35
Grip throttle l/h      46019-029                                               1 of         $65
Band fuel tank  92072-029                                                     6 of        $4
Round rubber pad   46041-024                                               1 of        $15
Rubber pads  92075-1226 50x 35 mm                                    2 of        $3
Tube rubber  703A09900                                                       2 of        $18
Bolt 113B12151A  160x12mm                                                5 of        $10
Rotary valve disc  12001-002  fits 1968 to 1981                      1 of        $80
Plate 14014-027        5 of        $3
Plate 13169-009        5 of        $12
Disc 13145-003        3 of        $45
Muffler baffle 18033-058 fits z1 –zb                         1 of   255long        $100
Muffler baffle 395 long 47mm end cap 22mm exhaust hole       1 of        $80
O rings
92055-104        90 of        $20  Total
92054-009        2 of        $1    Total
92054-010        2 of        $1    Total
92052-002        5 of        $1    Total
92054-003        4 of        $1    Total
Oil seal   92050-037  Tcy 32-62-10                                         3 of         $10
Oil seal   92053-008                                                              2 of         $20
Bearing Main 601B6305                                                         2 of         $25
Engine bits
Tool kit Kawasaki engraved on front  56007-020                    2 of          $45
Crankshaft left side 13037-054                                             1 of          $150
Crankshaft right side 13038-050                                           1 of          $150
Big end needle bearing  13034-035                                       1 of          $70
Little end bearing        1 of           $20
Clutch hub  13087-035                                                        1 of           $90
Clutch wheel  13086-014                                                     1 of           $50
Pusher clutch 13114-008                                                     2 of           $40
Shift rod  13209-013                                                           1 of           $20
Flywheel  21050-014                                                           1 of           $210
Change drum pin plate holder  13142-014                             5 of           $14
Plate gear change drum positioning 13169-012                      5 of           $12
Exhaust manifold  18062-007                                               1 of           $75
Exhaust manifold gasket  18050-005                                    1 of            $10
Used parts good condition
450 Cylinder, Head and std piston, new set of rings  Good used condition             1 of  $300, 116 ,80, 80 new price                                                      Sell for $400 complete.
Conrod complete Good used condition, fits 450, 400                       1 of       $110
Clutch, 90% complete suit 450, 400                                              1 of       $100
Cdi / points cover, small scratch only  13087-035                           1 of       $80
Clutch cover  slight damage   14032-087                                       1 of       $120
Gear cluster output shaft 1st, 2nd,3rd,4th,5th & kick idle gear very good condition. Total $400
Shock dampers 42014-022                                                        8 of       $15
Drum Hub assembly  42005-045-21 complete                             1 of       $250
Kick start complete good condition 13058-046                            1 of        $100
Hammer head shocks. Rebuildable                                             3 of        $200 total
Complete clutch, 250 A4 /A5 I think                     1 of         $200
Clutch backing plate ( has 125 stamped )            1 of          $85
Special Tools ( new )
Socket  57001-371  150mm long                                  2 of           $10
Socket handle  5700-370                                       3 of            $10
Socket long 57001-372 13ml ½ drive 300 long  4 of            $10
Socket long 57001-371 13ml ½ drive 150 long  1 of            $10
Socket long 57001-301 13ml ½ drive                   1 of            $10
Socket  57001-181                                                   2 of            $10
Adapter  57001-294                                                4 of             $10
Adapter  57001-246                                                1 of             $10
Driver  57001-297                                                   2 of             $10
Driver  57001-298                                                   1 of            $10
Driver  57001-288                                                   3 of            $10
Driver  57001-191                                                   1 of            $10
Ring compressor   57001-921                                   2 of            $80
Base (aluminimun ) 57001-341                                1 of             $20
Driver   57001-380                                                  1 of            $15
Driver   57001-1026                                                1 of            $15
Assorted new parts
Fuel tank, A2, A3 I think    Slight damage near filler hole.              1 of.     $350
Rear fender 35022-110                                                               1 of      $150
KX 400 Parts Catalogue very good condition.                                1 of      $60
Chrome covers  102 od, 57 id, 4 screw holes                                4 of      $15
Brake pedal return springs 43005-009                                         5 of      $4
Springs  43005-028        4 of      $5
Pin 32111-004  ( A17P6 )                                                           6 of      $2
Plug  92066-035        2 of       $10
Spring    42020-004 rear brake                                                  4 of       $10
Air box drain plug  92067-020                                                    1 of       $10
Air cleaner connector   11026-008                                              2 of       $7
Air box gasket foam 11017-011                                                 4 of        $5
Front blinkers (23048-027 lens number only)                      2 of       $100 set of 2
Rear blinkers ( 23044-009 lens number only )                      2 of      $100 set of 2
Pictures can be sent of items of interest.
Email me if you have any items of interest
[email protected]
Offline Dungar Pilot
Re: KX 450, KX 400 & KX A5 new and used parts for sale
« Reply #1 on: September 06, 2018, 09:20:37 pm »
Thank you for the detailed photos Kel, that part is slightly different to what I am looking for.
