Author Topic: Honda xl jetting 34mm mikuni  (Read 35127 times)
« on: July 25, 2018, 01:15:43 pm »
Hi anyone have a known jetting specs for a xl 250 & xl350/420 both are side port engines
My 250 is giving me greif new points changed coils still wont go and it did only once at nepean but now wont run
Jim
Re: Honda xl jetting 34mm mikuni
« Reply #1 on: July 25, 2018, 06:19:24 pm »
ive had a ton of issues over the years with the points on those things, look again at them..
Offline bazza
« Reply #2 on: July 25, 2018, 08:13:46 pm »
Allways use Honda Genuine points,most with generic ones have problems
Embrace patina
« Reply #3 on: July 25, 2018, 10:21:22 pm »
what about the condenser,when was it last replaced?they dry out with age and a dud condenser means no spark
Offline bazza
« Reply #4 on: July 26, 2018, 12:28:50 pm »
My mikuni came from Hatrix pre jetted spot on for XL250
« Last Edit: July 26, 2018, 01:35:58 pm by bazza »
Embrace patina
Offline Momus
« Reply #5 on: July 26, 2018, 01:31:43 pm »
Any up and down movement- wear- of the advance mechanism, or shudder, the cam will make life hard for the points.
If you love it, lube it.
« Reply #6 on: July 28, 2018, 08:44:09 am »
Thanks for the replys will start from the begining rewire
« Reply #7 on: July 30, 2018, 09:00:31 am »
CT 110 electronic ignition fits, MAKE SURE THE FIBRE WASHER IS IN PLACE BETWEEN THE POINTS AND BACKING PLATE.  You need to fit a much smaller needle tube to the 34mm.
Offline Davy123
« Reply #8 on: August 28, 2018, 04:29:18 am »
fit an electrex world electronic ignition and your bike will be transformed ... best cash youll spend
« Reply #9 on: August 28, 2018, 09:54:21 pm »
 :new points 30 piolet will see how it goes at nepean in a few week
Offline bazza
« Reply #10 on: August 29, 2018, 07:05:13 am »
jim did you manage to get genuine honda points
Embrace patina
Offline Davy123
« Reply #11 on: August 30, 2018, 04:27:52 am »
34mm mikuni jetting in my vmxl ... 6DH3 needle ,P5-159 needle jet ,35 pilot jet , 220-250 main jet , 2.5 - 3.5 slide and remove air jet , 50/50 av gas and super unleaded mix, electronic ignition , bored ported cam etc etc  ..
« Reply #12 on: September 01, 2018, 11:41:52 am »
After market points 15.00 gen honda 60.00 min
Offline bazza
« Reply #13 on: September 02, 2018, 06:59:11 am »
Yep and no comparison to reliability and performance notice at top end if your motor has been modified
Embrace patina
« Reply #14 on: September 02, 2018, 08:09:41 am »
will find out on the 16th will let you know how it goes
jim
