Author Topic: Quality of replacement COUNTER SPROCKET help & advise ?  (Read 9590 times)
« on: June 23, 2018, 02:04:37 pm »
Gooday all,
Has anyone ever noticed which replacement brands are hardest or longer wearing?
Or which brands are junk and wear quickly,,, = metal quality?
I am repairing building some XR600 engine projects for myself.
The counter shafts have flogged out on the spline where the sprocket mounts on.
I am thinking cheap quality sprockets maybe wear quickly, then in turn ruin the shaft as they flog
 back and forth? ?
Re: Quality of replacement COUNTER SPROCKET help & advise ?
« Reply #1 on: June 23, 2018, 03:45:30 pm »
cant help with whats the best brand as been out of the trade too long but your bike is the 2nd bike ive heard of that chewed the splines out on the countershaft which should be harder then the spocket,maybe Honda didn't heat treat it hard enough
Offline Momus
« Reply #2 on: June 23, 2018, 04:38:27 pm »
The countershaft should be harder than the sprocket and probably is OE but who knows aftermarket. The wear is mostly caused by grit IMHO.
Shafts can be repaired fairly easily by annealing, weld building, recutting and case hardening.
If you love it, lube it.
« Reply #3 on: June 23, 2018, 05:33:52 pm »
 back and forth? ?
I have seen this happen to the CT110 posty bikes. Ruins the shaft.
I have not seen it on the NBC110's yet but i replace the sprockets and chains as a set fairly often, probably before the sprockets get real worn but the crappy OEM chains wear out sooner. The older CT's we could run DID o-ring chains on which last many times longer and the sprockets would get more use so more chance to wear on the splines. Honda & AP wont allow aftermarket o-ring chains on the bikes now.
« Last Edit: June 23, 2018, 05:41:09 pm by LWC82PE »
Offline dont
« Reply #4 on: June 24, 2018, 09:21:56 pm »
I've heard of the problem and the theory was that the sprockets don't have enough contact width on the spline. The solution I believe was the make an adapter thingee that gave in effect a wider inner base to the sprocket. Sounds good.
Offline Kenneth S (222)
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« Reply #5 on: June 24, 2018, 10:09:21 pm »
I've used PBI on my race bikes for about 4-5 years and they have lasted really well. I order them direct from the US, the shipping is reasonable and I usually receive them within 2 weeks. https://shop.pbisprockets.com/
Kenneth S
Go For It
Race Bike History
