Author Topic: Best value twin shock?  (Read 23163 times)
Offline Curtis
    • japspec.com.au
« on: June 15, 2018, 09:12:17 am »
A...Is it possible to get a twin shock rear end to work ok or do you just deal with average suspension? (RM400)
B...What is the best value for money option for twin shocks price and performance in mind? I cant justify spending a thousand bucks on shocks..preferably half that would be nice. ... 8)
Offline Ted
Re: Best value twin shock?
« Reply #1 on: June 15, 2018, 10:23:51 am »
Yes it’s possible. I assume it’s a race bike. But you’ll get nothing for $500. Around $2,000 will get you a dyno tuned set of Ohlins. Throwing $500 at a pair of shocks is a total waste of money if you want to race it
81 YZ 465 H   77 RM 125 B
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
« Reply #2 on: June 15, 2018, 10:49:46 am »
A set of Hi-Low speed shocks will get you close to a linkage bike . I have built many of them . For the likes of Burt , Ballards etc, people that appreciate the difference .You will get what you are paying for . Usually posts like that , trigger a wind  up by the usual suspects , that are on financial  kick backs or rewards ..... ;).Here is the link to the High -Low shocks . When you buy direct you are not paying money towards  big commissions or kickbacks and you end up with a price for a set of top shocks that  is well below 2K .  Made to order for rider weight , color scheme , lenght  and other applications .  https://store.suspensionshop.org/suzuki/mx/1970-1979.html
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
Offline Ted
« Reply #3 on: June 15, 2018, 04:19:14 pm »
Financial kickbacks and rewards you say. Where do I apply?
Offline Jumbo J
« Reply #4 on: June 15, 2018, 05:32:52 pm »
Sean at SOS in Penrith does an entry level custom made Koni style shock for around $600 pr.
Nick at Technik also in Penrith, and Steve at Suspension Improvements in Brissy.  you should give these guys a call  Curtis .
Offline Gippslander
« Reply #5 on: June 15, 2018, 06:12:19 pm »
have got shocks from YSS - he asked me questions to make sure the bike was correct for the year, about my riding ability, my weight and even the ride height but first telling me what standard was. for $1200 the shocks were very close to correct when delivered and have done a lot of races without fault and no leaks at all.
Offline Ted
« Reply #6 on: June 15, 2018, 07:52:00 pm »
Take your RM 400? shocks to Sean at SOS and have them rebuilt. Best bang for your buck. This advice comes from the best suspension guy in the business.
Offline Momus
« Reply #7 on: June 15, 2018, 08:21:39 pm »
^This
If you love it, lube it.
« Reply #8 on: June 16, 2018, 08:17:01 am »
the ITC huskies were close to the best stock twin rear you could buy at the time and with some damping changes are pretty good. (all other bikes were single shock by then ::))
« Reply #9 on: June 16, 2018, 09:10:52 am »
the ITC husrkies were close to the best stock twin rear you could buy at the time and with some damping changes are pretty good. (all other bikes were single shock by then ::))
[d/quote]
Agreed
Offline Toolboy
« Reply #10 on: June 16, 2018, 10:17:13 am »
On my 79 RM400 i fitted Works Performance Shocks...just happened to be the long lost days of the Aus dollar being higher than USA,,,so yes a $500 pair of shocks can work,,,,i was so impressed with the feel of the rear end i have fitted to my RM370 and TM400 Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline Tomas
« Reply #11 on: June 16, 2018, 06:41:16 pm »
Did shocks on my 79 RM125 myself. Only cost me around $130 in parts+materials. Now i have a set of rebuildable shocks with basic adjustment(Suzuki style :))and easy to get parts for. Used ohlins seal heads and and 12mm hardchromed CrMo shafts. Someone mentioned Ohlins shocks for thousand plus dollars. Only adjustments you get is changing air pressure and spring preload.
« Reply #12 on: June 16, 2018, 10:14:23 pm »
Its interesting reading a few articles from back in the day where they changed the oil and pressure in the last of the suzuki KYB's (79-80) usually by fitting aftermarket reservoirs, and they said it made a noticeable positive improvement. The stock oil was pretty bad and changing that alone made a difference. The damping rates still may not suit everyone so if you can fix that, fit better seal heads and floating pistons (stock ones are prone to sticking and jaming), you may end up with a fairly decent set of shocks. You get large shafts, 36mm bodied De-Carbon shocks that are the correct length and stroke. I dont think you can get any of that for under $500 in a new shock. i have known people to have RAD rebuild the stock KYB's and they were very happy with them.
Offline Curtis
    • japspec.com.au
« Reply #13 on: June 18, 2018, 10:41:25 am »
Thanks everybody, I will be investigating all options...and saving a few more bucks
Offline Kenneth S (222)
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« Reply #14 on: June 18, 2018, 05:50:17 pm »
Agreed. The Works Performance Shocks are excellent feeling shocks.
Kenneth S
Go For It
Race Bike History
