Author Topic: 1979 YZ80F  (Read 25954 times)
Offline rocketfrog
Re: 1979 YZ80F
« Reply #15 on: July 06, 2018, 12:53:16 pm »
There you go, every days a school day! I always thought that the airboxes where the same part, usually a change in number equates to a change in design and there it is. This post makes me feel like resurrecting my YZ80E project. I put it on the back burner ages ago and migrated to other projects. Not before amassing a heap of bits and scouring every source I could think of for the elusive airbox. I think I am going to fabricate one from aluminium, it will go with the translucent side panels and DG arm and head to give it a works mini flavour. Doing a concourse resto on a YZ80 from this era seems like an expensive exercise. I do like the stock look, but the late 70s YZ80 hot rod up real nice.
Re: 1979 YZ80F
« Reply #16 on: July 07, 2018, 09:14:29 am »
go the custom look...get a pipe man to make a trick cone pipe and drill & fabricate to your hearts content
Offline rocketfrog
Re: 1979 YZ80F
« Reply #17 on: July 08, 2018, 12:46:05 pm »
I have an old school nos PK Racing pipe with a sort of built in silencer so the tip is about the size of a red bull can which looks like a the pipe has no stinger and silencer like a traditional set up. It has a heat shield with holes and PK stamped into it. Fitted, it looks like a shot gun barrel exiting just in line with the cut-out in the side cover.
 I have seen these minis accessorised with aftermarket bling to the hilt and they look great. I have a DG arm which looks cool, but there is a company which made a an alum arm out of aerotube (California based - something like CRP?) which looks very unique and trick.
Moto-Tek ignition set ups, Luft shocky with remote reservior and a whole gamit of bolt on goodies could be had for this era of mini. If Shinobi made a water cooled head kit for the YZ80's, I would like to fashion a Mini version of Hannahs' 0W27  with white guards, translucent plates and yellow tank with black speed block graphic - and of course the radiator mounted up front like the J's had.
I sent DC Plastics a seat foam to copy about 18 months ago and now you can get a replica foam for the YZ80E plus there are a lot of aftermarket bits still around for them so building up a respectable YZ80E rodder is probably easier and cheaper than trying to go for concourse.
Offline alexbrown64
Re: 1979 YZ80F
« Reply #18 on: July 08, 2018, 06:25:56 pm »
Yep Husky/Rocket, I think the E/F can look and run great as those DG package racers. I guy called Ron Boucher (I think) on Facebook and Vitalmx sells hop up parts for them.
My E and F are going back to original....not concourse, but clean.
Thanks for getting the seat foam set up through DC Rocket. I bought two. The E/F have the same shape on top, but the seat bases were slightly differently molded, but will fit both bikes.
I have a nos F seat cover to go on. The E seat cover is new replica from Canada. It has the piping like the original. The Thai ones don't have the piping.
The problem with the E was the cheesy frame. I have the Yamaha gusset kit I will TIG on. I will take pics of the frame restore. One rare item I found was the wire looking front brake cable guide. Also, I found nos front number plate wire mounting hooks and rubber band..
I think the E is a great bike to do up as a project. You should get yours up and started Rocket, as a DG racer would be worth a lot of money, and look great. I would love to see some pics of that.
My collection of parts is almost complete for the E, except for plastics. I may take my 125G, 80E and 80F hardware to the zincers to get done as a batch.  Then take all the frames, hubs, motors etc to the powder coaters to get done as a batch.
Offline rocketfrog
Re: 1979 YZ80F
« Reply #19 on: July 09, 2018, 11:09:10 am »
Yeah, Rob Boucher was advertising for parts wanted on the Marks Swap Site. I contacted him a while ago to see if he was interested in the DG parts and he sort of went cold, I think he might have suspected a scam or something - it happens and once you get burned you are shy of getting done again. So I decided to sit on it for a while and see if I get the urge to build it up, I bought it sight unseen from a seller on Gumtree claiming it was a 1980 G model - which is what I wanted. When I got stuck with it I asked if there was any interest in a trade for a G model but no luck there either. So now I have the cheesy framed E which has had the Gusset kit installed previously and a bunch of aftermarket goodies, still not the G but I am somewhat inspired to build it up as a DG Racer. The cool aero tube swing arms were made by a company called CRF - Crotch Rocket Factory. I found a DG inlet manifold New in original package for $20! So there are still good bits around for the model at a reasonable price, I would like to find some period alloy rims for it. The tough one to get will be the 16 inch front in Aluminium, plenty of 17 inch around.
Offline alexbrown64
Re: 1979 YZ80F
« Reply #20 on: January 07, 2019, 08:00:45 pm »
I am still collecting parts for this old girl too.
Here are some pics from a Swedish brochure i picked up of the 79 YZ80..
Scored a nice rear mudguard the other day.. almost had to take out a second mortgage..
Also found a nos front number plate too.  Just need the white front guard.
