Author Topic: YZ/TT/TT front wheel width  (Read 15823 times)
« on: May 17, 2018, 09:00:19 pm »
Can anyone with one of these wheels tell me what the assembled width is or the sum of the following parts
brake plate depth at the center
left wheel bearing width
hub center spacer
right wheel bearing width
and width of what ever goes against the right bearing and the insidde of the right fork slider (spacer/Speedo drive?)
Part # = 1K7-25111-10-98
Part Description = HUB,FRONT LOW GLOSS BLACK
Model Count = 37
IT175D 1977 175 IT175 Dual-Purpose
IT175E 1978 175 IT175 Dual-Purpose
IT175F 1979 175 IT175 Dual-Purpose
IT175G 1980 175 IT175 Dual-Purpose
IT175H 1981 175 IT175 Dual-Purpose
IT250D 1977 250 IT250 Dual-Purpose
IT250E 1978 250 IT250 Dual-Purpose
IT250F 1979 250 IT250 Dual-Purpose
IT250G 1980 250 IT250 Dual-Purpose
IT250H 1981 250 IT250 Dual-Purpose
IT400C 1976 400 IT400 Dual-Purpose
IT400D 1977 400 IT400 Dual-Purpose
IT400E 1978 400 IT400 Dual-Purpose
IT400F 1979 400 IT400 Dual-Purpose
IT425G 1980 425 IT425 Dual-Purpose
IT465H 1981 465 IT465 Dual-Purpose
TT250G 1980 250 TT250 Off-Road
TT500D 1977 500 TT500 Off-Road
TT500F 1979 500 TT500 Off-Road
TT500G 1980 500 TT500 Off-Road
TT500H 1981 500 TT500 Off-Road
YZ100D 1977 100 YZ100 Competition Motocross
YZ125D 1977 125 YZ125 Competition Motocross
YZ125E 1978 125 YZ125 Competition Motocross
YZ125F 1979 125 YZ125 Competition Motocross
YZ125G 1980 125 YZ125 Competition Motocross
YZ125H 1981 125 YZ125 Competition Motocross
YZ250D 1977 250 YZ250 Competition Motocross
YZ250E 1978 250 YZ250 Competition Motocross
YZ250F 1979 250 YZ250 Competition Motocross
YZ250G 1980 250 YZ250 Competition Motocross
YZ250H 1981 250 YZ250 Competition Motocross
YZ400D 1977 400 YZ400 Competition Motocross
YZ400E 1978 400 YZ400 Competition Motocross
YZ400F 1979 400 YZ400 Competition Motocross
YZ465G 1980 465 YZ465 Competition Motocross
YZ465H 1981 465 YZ465 Competition Motocross
Offline Oldfart
Re: YZ/TT/TT front wheel width
« Reply #1 on: May 18, 2018, 04:42:45 pm »
What you up to now .....is this for the on going Ts hybrid ???
« Reply #2 on: May 18, 2018, 05:23:26 pm »
No, i am trying to identify some forks.
« Reply #3 on: May 18, 2018, 09:27:49 pm »
Why not put a pic of the forks up,some one on here will know what they are. With Yamaha front hubs their all the same dimension from yz A models to the last of the front drumy's on tt600L but little things like speedo drives differ on it400C to the D model on hubs
« Reply #4 on: May 18, 2018, 09:44:50 pm »
I know what the forks are ;), they are aftermarket KYB but i want to know what front wheel was originally in them. I suspect yamaha because the brake anchor tag is about 1-2mm too thick for any suzuki plate. I will have to check a YZ465? TLS brake plate i have. If that at least locates, it would tell me it at least had a yamaha hub. I have around a 131-132mm gap for wheel to work with.
« Last Edit: May 18, 2018, 09:49:47 pm by LWC82PE »
« Reply #5 on: May 18, 2018, 09:58:51 pm »
OK I see all,the G/H TLS plate are the same dimensions from D model to H model yz/it backing plates
« Reply #6 on: May 19, 2018, 08:24:44 am »
I think it might be from TT500 but i am not 100% sure. I was told that. TT did not have speedo drive. Would those wheels fit a 131-132mm gap properly?
Do you know the front wheel bearing numbers? i can look up what size they are. Oh and this had a 15mm axle too......
My info says left and right bearings are both 6202 (11mm wide ) although partzilla says they are different numbers but i think one may be sealed and onw unsealed?
Looks like i need to know these parts
11 - 11mm
8
9
10 - 11mm
21
don't think part 22 adds to the width? Says its a dust cover.
I just tried  a YZ TLS brake plate and it does not fit the fork. I was thinking it would. The brake lug does not reach the plate, plus the brake lug is 18mm thick and too thick for the 16.6mm wide slot in the plate. Maybe the single leading show TT/IT plates are different? I am stil pretty sure its going to be yamaha but if all their plates are same spec as the  YZ TLS then i have no fricken idea.
« Last Edit: May 19, 2018, 08:47:04 am by LWC82PE »
Offline mick25
  • Hunter valley NSW
« Reply #7 on: May 19, 2018, 06:31:51 pm »
Leith
The two wheel bearings are the same left and right .
Yes that is a plastic dust cover and slips over the wheel spacer .
I have a YZ465 brake plate and single TT500 brake plates both types I can measure those for you if you want ?
TT500 bikes did come with speedos I just sold a NOS lighting kit with Speedo and Speedo drive all brand new in a box with manual .
I have the Yamaha hubs if you need the measurements.
« Last Edit: May 19, 2018, 06:36:29 pm by mick25 »
« Reply #8 on: May 19, 2018, 07:38:42 pm »
Yes that would be good Thanks. i thought the lighting/speedo kits for  TT were an optional add on kit from the TY trials bike that was only added by some local dealers.
I reckon go with the TT500 plate first. Measure the width of the slot in it. Has to be 18mm or slightly wider, probably more like 19mm as the brake lug is tight on 18mm thick so an 18mm slot would be very tight still.
« Last Edit: May 19, 2018, 07:40:46 pm by LWC82PE »
Offline mick25
  • Hunter valley NSW
« Reply #9 on: May 19, 2018, 08:41:06 pm »
Yes the Speedo was optional you need to remove the wheel spacer and replace with Speedo drive .
I’ve measured two TT500 brake plates the slot gaps vary from one to the other but I say a bit of wear and tear over the last 40 years .
One plate slot is 16.25 - 16.50
The other plate   17.20 - 16.86
The YZ465 tls brake plate fits on the later model TT500 forks 79,80,81
With no mods needed I fitted one just to see .
« Reply #10 on: May 19, 2018, 09:16:12 pm »
Ok so it looks like no Yamaha plate/wheel was in these then as 18mm  lug wont go into any of those. Mystery deepens now. Thanks
« Reply #11 on: May 20, 2018, 08:23:18 pm »
That's a long list of wheels to try to identify forks from, they were also a lot of different forks for all those models.
You would be better concentrating on backing plate lists and identifying fork attributes
For 250 and big bores;
YZ D models had a shorter underhang under the axle
YZ E & F models have a longer underhang and also have a fake nipple for the oil drain just above the real one
YZ models have the drain behind the fork
IT models have the drain at the side of the fork, up to 81/82 as far as I know
125's were a smaller diameter.
Early TT/XT were in line axle
Later TT/XT were leading axle but have a short underhang not unlike the YZ D models
« Reply #12 on: May 20, 2018, 10:07:49 pm »
Well they were sort of universal with slight variances for the particular wheel that went in them. I was sure it was going to be yamaha but if all the  TT/XT/IT/YZ plates have 16-17mm wide slots they wont fit.
There is  a slim chance a 76-77 RM250/370 brake plates fits. I have not got one to check and only have a C plate and i know that does not fit
It still does not make sense because they run 12mm axle and the LH slider is drilled for 15mm
Would a 130mm suzuki plate a yamaha hub? and then maybe they just drilled the brake plate out to 15mm? i dont know. I have tried asking the hguy i got them off but i doubt he remembers or has any photos of what wheel was fitted.
« Reply #13 on: May 21, 2018, 09:51:45 pm »
Ahhh, your not looking at the forks for ID so they must be aftermarket, I still think you should concentrate on the backing plates.
Some Yamahas have the lug in line with the fork and some are at an angle, more to the rear of the fork tube, that should whittle the suspects down a bit
« Reply #14 on: May 21, 2018, 10:34:51 pm »
It would only be a leading axle fork plate. I would have expected yamaha would have use a common width in the plate slot for everything 77 to about 81.
Mick has already ruled out the TT500 plates.
