Author Topic: RM125B forks Wanted  (Read 14395 times)
Offline micko
RM125B forks Wanted
« on: May 01, 2018, 03:30:16 pm »
and triple clamps - worth a try, must be good nick
Re: RM125B forks Wanted
« Reply #1 on: May 01, 2018, 04:55:26 pm »
I have PE ones that are more or less the same, unless your racing for top spots in pre 77 class they be fine.
Offline micko
« Reply #2 on: May 01, 2018, 06:44:08 pm »
building it up for my son to take to the nats later this year, do they have the overhang and what year
« Reply #3 on: May 02, 2018, 01:12:03 pm »
They are totally different, only common parts are the seals and fork boots really. Might??? be ok at a local club race but the 78-79 PE ones certainly will not be at Nats as they are off later models and the parts are not the same anyway.
For 125b forks you need to find the ones with these numbers cast near the axles holes on the sliders  X3363L and X3363R and they measure 295mm from the axle hole to the top of the slider. In totally stock form they do not need restricting to 9" either. Don't be fooled in to thinking RM250C (alloy tank model) forks are the same or close enough either.
« Last Edit: May 02, 2018, 01:23:55 pm by LWC82PE »
Offline micko
« Reply #4 on: May 02, 2018, 03:18:18 pm »
thanks for that info, appreciated
« Reply #5 on: May 02, 2018, 05:57:25 pm »
Sounds like the PE forks are off the list if your son is riding the nats.
Offline micko
« Reply #6 on: May 06, 2018, 01:22:57 am »
Looking that way, gotta keep within the rules
Offline Oldfart
« Reply #7 on: May 06, 2018, 07:27:18 am »
early Yamahas ran the same forks .... just different triples
« Reply #8 on: May 06, 2018, 03:49:12 pm »
They are similar. I am not sure what travel they have
https://www.ebay.com/itm/1977-77-Yamaha-YZ125-YZ-125-Front-Forks-Suspension/401409950827?hash=item5d75e5c46b:g:aH4AAOSw~jpZxaDT
i suspect the axle holes are 15mm though
Offline motomaniac
« Reply #9 on: May 06, 2018, 09:34:13 pm »
the yz forks don't have as much slider below the axle.
Offline micko
« Reply #10 on: May 08, 2018, 11:52:24 am »
ok, so I tracked a pair down in the US. Guy claims he personally pulled them out of a RM125B but they don't have those numbers stamped (only have NN stamped) waiting for him to confirm the 295mm measurement, any other way to tell ?
« Reply #11 on: May 08, 2018, 12:42:36 pm »
I have seen bikes with incorrect forks on them.  Sent you a PM
Offline micko
« Reply #12 on: May 08, 2018, 12:54:11 pm »
sent you some photos via email, cheers
Offline micko
« Reply #13 on: May 28, 2018, 01:47:13 pm »
Got to do your home work, as the seller said he personally pulled them out of the 125b himself. Ended up being RM400 forks lol
Lucky I asked lots of questions
Offline burns60
« Reply #14 on: August 06, 2018, 01:03:23 pm »
gday i goy set of forks complete from 1980 125t might have triple clamps to ,if thats any good for you ,,if your still looking cheers steve
