Author Topic: klx250 inner rotor kit  (Read 14370 times)
Offline Kane Mcguire
« on: April 01, 2018, 05:11:27 pm »
Just bought an inner rotor ignition for the klx, so looking forward to the improved throttle response instead of having a cup of tea waiting for it to get going out of corners! I will report back.
Offline grouty
Re: klx250 inner rotor kit
« Reply #1 on: April 02, 2018, 01:23:00 am »
Not sure a new rotor and ignition will cure that. The original ones are quite bomb proof. The only thing I have replaced on mine since 1982 is the coil. Check the pickup air gap. Make sure your cam is set on the "KZ200" marks and look at your carb. The valve seats wear quite quickly too. Check your compression.
Thumpers Rule !
« Reply #2 on: April 02, 2018, 07:42:39 pm »
Its the lighter flywheel I'm purchasing it for. About 4kg lighter!
Offline grouty
« Reply #3 on: April 02, 2018, 08:26:21 pm »
Hmm  :) Looking forward to the report.
Thumpers Rule !
Offline grouty
Thumpers Rule !
« Reply #5 on: April 05, 2018, 07:47:46 pm »
https://hpi.be/item.php?item=068K448
I ordered it and now they are saying out of stock. I'm going to contact your site and check freight costs etc. Iv started machining the standard flywheel, but not much material can come off.
« Reply #6 on: April 05, 2018, 07:51:09 pm »
They are the same part numbers. The Belgium site told me they manufacture them. Who to believe?
