Author Topic: New (old) Project  (Read 217488 times)
Re: New (old) Project
« Reply #30 on: March 24, 2018, 03:13:21 pm »
sounds great but not getting the picture literaly, well done!
Offline grouty
« Reply #31 on: March 25, 2018, 12:02:20 am »
I can see a dirty CCM. Can anyone else see it ?
Thumpers Rule !
Offline djr
« Reply #32 on: March 25, 2018, 12:26:33 am »
sorry, cant see that one
can see all others
Offline grouty
« Reply #33 on: March 25, 2018, 03:52:03 am »
Ok ...... let's try again.
This is the original one at Farleigh Castle back in 2007.
Thumpers Rule !
« Reply #34 on: March 25, 2018, 09:30:22 am »
 :o :o :o
Offline Butcher
« Reply #35 on: March 25, 2018, 09:15:43 pm »
what oil do you run in the engine/frame and chaincase?
Offline grouty
« Reply #36 on: March 26, 2018, 09:43:59 am »
I run R40 for all of it. I change the oils after every race meeting.
It's the only oil I have found that will stand the heat. (not wishing to start another oil debate !)
Thumpers Rule !
Offline grouty
« Reply #37 on: March 26, 2018, 09:51:30 am »
A bit of beating the crap out of a piece of aluminium ......
Thumpers Rule !
« Reply #38 on: March 26, 2018, 04:48:44 pm »
is that castrol castor oil ?
i used it in my weslake 500 speedway. it can "pit" engine internals if sitting for time.
Offline geoff
« Reply #39 on: March 26, 2018, 05:05:03 pm »
"is that castrol castor oil ?
i used it in my weslake 500 speedway. it can "pit" engine internals if sitting for time."
I have used castor based R40 for many years and provided its changed on a regular basis gives no trouble. I think you might find that methanol fuel is the problem being gyroscopic and causes water formation and rust if the oil is left over a long period.
I only use AVGAS these days but always flushed the fuel tank with petrol when using methanol and dropped the oil after each meeting.
« Reply #40 on: March 26, 2018, 05:50:13 pm »
hygroscopic is term you want ...gyroscopic has a "gearloose" .....(joke for baby boomers) 8)
Offline geoff
« Reply #41 on: March 26, 2018, 10:14:21 pm »
It's my dyslexic digit, it should be as you know hydroscopic. It happens with arthritic fingers and single digit keyboard skills
Offline grouty
« Reply #42 on: March 26, 2018, 11:54:40 pm »
Well .... other than bolting the sump plate back on, it's done.
I have had a good 15 minute ride around a friends field, and all seems fine. I have changed all the oils and the spin on filter. No horrors found. I cut the filter open just to look in there too. Easter Sunday will be the first race meeting for it, so we'll see what happens. I intend to take it easy .... at first  ;)
Thumpers Rule !
Offline PEZBerq
  • Brisbane
« Reply #43 on: March 27, 2018, 08:02:27 am »
Looks lovely grouty. May I enquire what the sheet of newspaper on the floor is for?
« Reply #44 on: March 27, 2018, 09:22:16 am »
std on all pommy bikes ;D
