Author Topic: Montessa 250 VR  (Read 15262 times)
Offline 2 shocks
  • Gods Country !!
Montessa 250 VR
« on: December 29, 2017, 01:21:04 pm »
Would anybody know the original needle jet and needle size for a 1974 - 75 Montessa VR 250, Bing Carby
Ken Baker
Re: Montessa 250 VR
« Reply #1 on: December 29, 2017, 10:13:11 pm »
Contact Ross Nimmo on Facebook Ken, he's your Monty man
Re: Montessa 250 VR
« Reply #2 on: December 30, 2017, 09:00:46 am »
Contact Jared bates at Southwest Montesa, a wealth of knowledge & a real nice, helpful guy.
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: Montessa 250 VR
« Reply #3 on: January 03, 2018, 06:35:35 am »
Ken,
Bing 11500- 34mm
Main jet- 155/160
Low speed jet (pilot)- 50
Needle jet- 2.85
Needle- 46-281/46-283
Offline 2 shocks
  • Gods Country !!
Re: Montessa 250 VR
« Reply #4 on: January 11, 2018, 08:25:04 am »
thanks to hoony mick hughes and cappra problem solved
Offline Nebo
Re: Montessa 250 VR
« Reply #5 on: January 27, 2018, 12:03:51 pm »
    Would not use this jetting with Modern Fuel.
    It will Seize.
Offline 2 shocks
  • Gods Country !!
Re: Montessa 250 VR
« Reply #6 on: January 27, 2018, 09:38:50 pm »
What would you recommend ?
Offline Nebo
Re: Montessa 250 VR
« Reply #7 on: January 29, 2018, 02:46:00 pm »
  To be Safe  . Go 165/170 main jet.
   Run BP Premium Unleaded 98 Octane.
   32. 1 Mix.  Castrol TTS or Motel 800.
    NGK B9EGV  spark Plug.
     Timing should be 2.5/3 mm BTDC.
     Give it run and check for sound of Detonation / Pinging.
     Do a plug reading with a new Spark Plug.
Re: Montessa 250 VR
« Reply #8 on: January 29, 2018, 02:52:34 pm »
With no reed valve motors and Bings, You may need to modify the slide cut away to get that nice crisp off the bottom pull.
Offline 2 shocks
  • Gods Country !!
Re: Montessa 250 VR
« Reply #9 on: January 29, 2018, 04:23:03 pm »
al
good info thanks
