Author Topic: dt1 question  (Read 40935 times)
Offline kenny
dt1 question
« on: December 04, 2017, 12:47:52 am »
hi
i had a question about the dt1 250 from 71
i bought an dt1 from the usa but the headlight is a sealed beam one and it is broken i know back in the day you just throw it away and got youself a new one , does anyone have an idea what kind off headlight i can use to replace mine
also i bought a dt1 barrel with on the side YC 246 cc i ve been told its a barrel of a dt1mx from 71 or 72 does annyone know if this is correct ?
thanks
kenny
Re: dt1 question
« Reply #1 on: December 04, 2017, 09:50:22 am »
The original headlight wasn't a sealed beam, they had a removable bulb. The light was the same pretty much on all the DT/RT series. They used a 6 volt 35 watt dual filament bulb.
If the barrel is an MX it will be chrome plated inside. I have had a look at one I have here and it only has the 246 marking on it with nothing else.
Of course it has to be piston port to be a DT1. The first of the DT2's came out in 71 with the reed intake but all the engine numbers started with DT1 up until the 74 DT250.
Offline OverTheHill
Re: dt1 question
« Reply #2 on: December 05, 2017, 06:42:55 pm »
DT1MX had a boreable cast liner cylinder [i have one] but DT1GYT kit cylinder was chrome [i recently sold one]. Assembled them new where i worked plus fixed them when they broke which was often lol. The DT1MX cylinders wore out pretty bad but the Chrome GYT Kit cylinder lasted well. I did end up with someones stuffed chrome bore that had an LA Sleeve fitted that was made out of real good stuff & lasted for ever & only recently sold that on a motor. I'll fight my way the crap & have a look at what's stamped on the side of the cylinder [DT1MX cylinder]. I'll find a pic so you can have a laugh at what it's on & not been run for years but does go & actualy fair goes like hell/ Just remembered i have a 360 crank in that one so 70x70mm whatever that works out too.
Re: dt1 question
« Reply #3 on: December 05, 2017, 08:17:51 pm »
All the ones I've seen must be the GYT kit. All the one's I've seen in the last 20 years has had the chrome bore and all are stuffed. I thought the DT1MX's were just a Dt1 with a factory fitted GYT kit but obviously not.
Offline OverTheHill
Re: dt1 question
« Reply #4 on: December 05, 2017, 09:50:47 pm »
Yep still plenty of oversize single ring DT1MX kits on ebay. Be lucky to find a genuine kit for a chrome bore as had a ring with parallel faces as opposed to keystone tapper top face that i 'think' the DT1MX had but might be wrong on that, different thickness anyway. Chrome cylinder ring was of a different material & F$%n Dopey Me finished off a pretty worn but usable cylinder that i had for 30/40 years & thought--give it another run & had a genuine piston but no ring, so shuffled through a box of old rings & thought 'that one' do as fitted ring groove & the bore. Took about 1 minute to absolutely bugger it beyond use & pissed myself RIGHT OFF. Mate did that in the mid "60's on a square barrel villiers starmaker motor, think he got a special cylinder for it & did the same thing without realising. I thought--i'll never make that mistake lol. DT1 GYT Kit we got in late "68 for the new square S/arm DT1. Complete top end plus carb & chamber plus a "21 front wheel. DT1MX by memory would've arrived in 1970 with the round tube S/arm & ready to race out of the box--well till the gearbox gave up the next week!!. Boss got an RT1MX--same bike bigger motor. I pinched that motor for my "68 DT1 for a meeting while he was off overseas. Was a bit of fun for sure. Anyway--forgotten the question.
Re: dt1 question
« Reply #5 on: December 06, 2017, 11:36:21 am »
DT1 talk certainly brings back memories for me having bought a round swingarm one S/H when I was 14. It came from a guy that worked at a Yamaha shop. Had all the lights on it but they soon came off and it also came with a GYT kit which went on. Certainly went better with the kit fitted but noisy as hell with that open chamber. My plan was to start racing it with a lowered frame after reading a magazine article on converting it into a MXer. I was talked out of it by my local MX expert and shop owner and bought a 73 TM125 instead. I kept the GYT stuff and sold the bike on but after looking at the barrel some 15 years ago found the chrome coming off with corrosion under it. Have made a sleeved and fitted it and just recently sold it for use on a VMX bike.
Not much to do with his original question but you get that.
Offline kenny
Re: dt1 question
« Reply #6 on: December 07, 2017, 02:44:07 am »
thanks for the information guys
the cylinder i have is boreable with reed intake
on internet i cant find anything of a cylinder that starts with YC
kenny
Re: dt1 question
« Reply #7 on: December 07, 2017, 10:44:38 am »
kenny
Reed intake will make it a DT2/3 or possibly a DT2MX, I had a look on a DT2 barrel and can't see YC anywhere only 246cc. Can you post a picture or a link to a picture?
A lot of people have been conned into buying bikes that are listed as DT1's only to find they are DT2/3's as they all start with DT1 engine and frame number. What type of cylinder is on the bike reed or piston port?
Re: dt1 question
« Reply #8 on: December 07, 2017, 12:43:07 pm »
Found this on Ebay.
https://www.ebay.com.au/itm/New-Yamaha-Headlight-Bulb-CT1-CT2-CT3-DT1-DT2-DT3-RT1-RT2-RT3-175-250-360-400-DT-/281985258943
It is a sealed beam probably like the one you have but there is a list of other Yamaha's that share the same size light.
I may even order one for my RT3 and keep it as a spare.
Thought I'd put up a photo of the RT3. It's had a front wheel rebuild with a new trials tyre and a new repo seat cover since the photo.
Offline OverTheHill
Re: dt1 question
« Reply #9 on: December 07, 2017, 02:07:52 pm »
Oh hell that's suddenly opened a different can of worms. reed i "72 on so you've either bought a DT2 or DT3 cylinder if it looks the same in the way it fits on, base gasket, head gasket etc. Or it's a DT2MX cylinder which looks a bit squarer in the fining, head fins are taller too if you have the matching head. Need pics please if pos. Only problem will be--if you 'do' have a "71 piston port DT1 7 go to fit a reed cylinder then there's a conrod length difference of about 5 or 6mm. Same problem doesn't happen with a 360 going from piston port to reed. Confusing myself now so i'll leave it at that.
Re: dt1 question
« Reply #10 on: December 07, 2017, 05:20:22 pm »
5mm longer conrod for the DT1 with a 5mm lower piston from the pin which puts the top in the same place.
Offline dont
Re: dt1 question
« Reply #11 on: December 07, 2017, 09:16:28 pm »
Found this on Ebay.
I'd guess its wrong pattern for legal use in aus.
Re: dt1 question
« Reply #12 on: December 08, 2017, 12:43:25 am »
Found this on Ebay.
That could be a problem but the Ebay site gave a long list other Yamaha's that share the same lens which could help in finding something.
One would have to be pretty brave to ride at night with those 6 volt light these days.
Offline kenny
Re: dt1 question
« Reply #13 on: December 08, 2017, 02:58:48 am »
thanks for the link off the head light
the cylinder that is now on my dt1 is one without a reed , i bought the other cylinder as a spare
here are some pic s off the cylinder and the dt1
kenny
Re: dt1 question
« Reply #14 on: December 08, 2017, 10:30:46 am »
My guess would be DT2MX as there are no fins cut away for the side pipe.
Looks like a lot of work on the bike to bring it back to original.
