Author Topic: Cheap XR200 carbs  (Read 15919 times)
Cheap XR200 carbs
« on: December 01, 2017, 12:33:12 am »
After a carb for my std xr200A so has anyone found a Chinese replacement carb that works out of the box or do I save my money and buy a gen Honda carb that will cost me an arm and a leg?
Re: Cheap XR200 carbs
« Reply #1 on: December 01, 2017, 08:18:48 am »
there has been good results with some of the replacements available. search the forum
Offline Curtis
    • japspec.com.au
« Reply #2 on: December 01, 2017, 08:29:39 am »
iv used a cheapy carb on some little hondas....not perfect but for the ridiculously cheap price it will get you out of trouble.
« Reply #3 on: December 01, 2017, 03:14:24 pm »
Why not just use a 30mm mikuni?
« Reply #4 on: December 01, 2017, 04:53:17 pm »
OK is it one of those Chinese 30mm mikuni's or one that is a gen mikuni's from hattrick the Aussie mikuni dealer?All I'm trying to find out has anyone found a Chinese xr200 carb that works like the std carb out of the box on a std engine and if so do they have a link to eBay for it,simples!I hate riding thumpers with more flat spots then a 50 cent coin has it just takes the fun out of riding them!Been there done that with TT500's with 38mm carbs on them and harder to fire up cold then a gas Barbi on a windy day!
Offline GD66
« Reply #5 on: December 02, 2017, 10:57:21 am »
Must have needed sorting then, they are great when they're set up right.
A VM30 is around $130 and they will jet it for you.
« Reply #6 on: December 02, 2017, 12:32:58 pm »
You could try one of these. Listed for Honda TRX250 and others. Tried carbs from here for other stuff and they were ok.
https://www.banggood.com/Carburetor-Carb-For-Honda-Recon-TRX250-1997-2001-ESTETHRS-250-p-981030.html?rmmds=search&cur_warehouse=CN
For $38 delivered what could go wrong?
« Reply #7 on: December 03, 2017, 07:51:37 pm »
I of the guys over here has been running a oko d slide carb on his xl175 that he uses in both vmx & vinduro for years. They're cheap enough although the chinese knockoffs can vary a lot
