Author Topic: Sloppy 34mm forks  (Read 5308 times)
Sloppy 34mm forks
« on: October 29, 2017, 07:32:06 pm »
I need to fit bushes to the top of my TY250 forks as both legs blow seals & if I grip each leg with the wheel out there is definite play in them
Does anyone know of a 34mm fork that has bushes in the top of the sliders or am I going to need to custom make a pair with a fairly thin wall thickness?
« Last Edit: October 30, 2017, 07:35:10 pm by tony27 »
Re: Sloppy 34mm forks
« Reply #1 on: October 29, 2017, 07:58:32 pm »
Possibly need to make them
Race Tech does not have 34mm
http://www.racetech.com/HTML_FILES/FMB-ForkBushings.html
Or try a bearing shop who has these
https://www.ggbearings.com/en/products/metal-polymer
Offline crossedup2
  • Never enough shed time.....
« Reply #2 on: October 30, 2017, 12:44:10 pm »
I will have the fork legs machined and these inserted in my RT1 racer over Christmas.
Any good machine shop should be able to do it!
http://www.ebay.com.au/itm/38-1006-ALL-BALLS-INNER-FORK-BUSHES-34-7-X-36-6-X-19-8-2-PCS/161348133783?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
If I had a half decent lathe I'd have a go myself. Can't be that hard!
Peter B
« Reply #3 on: November 04, 2017, 10:29:16 am »
So far the bushes listed over the counter are either 32mm or 35mm bore so it looks like it may end up being bronze bushes made to fit
