Author Topic: Dr 400 frame  (Read 18708 times)
Offline Oldfart
Dr 400 frame
« on: October 11, 2017, 12:08:26 pm »
As per title , chasing a Dr 400 frame, any leads would be much appreciated.
Offline Phil N
Re: Dr 400 frame
« Reply #1 on: October 15, 2017, 10:40:16 am »
Saw one with the swingarm and stand at Ross , Tiaro wreckers just yesterday .
Offline yamaico
Re: Dr 400 frame
« Reply #2 on: October 15, 2017, 10:02:19 pm »
DR250 frame any good to you? Are they similar?
Offline Oldfart
Re: Dr 400 frame
« Reply #3 on: October 16, 2017, 12:25:29 pm »
Not too sure if they are similar Yamaico  ...as I'm just wanting a bare frame only, to cut the cradle out of it.
« Last Edit: October 17, 2017, 08:38:11 am by Oldfart »
Offline David Lahey
Re: Dr 400 frame
« Reply #4 on: October 16, 2017, 01:49:07 pm »
If you just want the cradle, isn't the SP370 engine cradle the same as the DR400? I welded an RM250C rear subframe to an SP370 cradle just before the DR400 came out. I wish I'd known the DR400 was coming out and saved myself some work
previous pseudonym feetupfun
Offline Oldfart
Re: Dr 400 frame
« Reply #5 on: October 16, 2017, 04:02:04 pm »
SP have a large radius bend @ foot pegs sort of like a ? in reverse,   were as the Dr 400 is square ... same as all RMs and PEs  but has a curved front.
Re: Dr 400 frame
« Reply #6 on: October 16, 2017, 05:38:05 pm »
DR250 is a full floater. DR400 is a twinshock ;)
Offline cloggy
Re: Dr 400 frame
« Reply #7 on: December 23, 2017, 07:54:24 am »
I've got some spare DR400 frames butI live in the UK.  If you have no luck I may be able to cut up one for what you need. Depends on whether I can get the engine out
Offline Oldfart
Re: Dr 400 frame
« Reply #8 on: December 26, 2017, 09:12:48 am »
Cloggy thanks for the Offer. I may take you up on it.    Only need the cradle section,  being 90 mm above top  front down tube engine mount holes ( just below gusset ) and the rear  160mm above rear pivot bolt.
